Fingerprints, smudges, dust, or debris on the scanner glass, under the scanner lid, or in the document feed slot can cause lines and color bands. Clean these parts with a soft, lint-free cloth sprayed with glass cleaner.
Read one of the following sections for steps to clean these components, depending on your printer type.
Printer with flatbed scanner glass and lid
Printer with a document scan feeder
Printers with a flatbed scanner glass and lid
Clean the scanner glass and underside of the scanner lid with a soft, lint-free cloth sprayed with glass cleaner.
Turn the printer off, then disconnect the power cord.
Lift the scanner lid.
Spray a soft, lint-free cloth with glass cleaner, then wipe the scanner glass, glass strip (if present), the white backing under the scanner lid, and the white strip under the lid (if present) until clean, dry, and streak-free.
To protect the interior printer parts, do not spray the cleaner directly on the glass or on the underside of the lid.
Figure : Clean the scanner glass and under the lid, and any glass or white strips (if present)
White scanner lid backing
White ADF scanner lid strip (if present)
Glass ADF scanner strip (if present)
Main scanner glass
Reconnect the power cord, turn on the printer, then close the scanner lid completely.
Load the original document or photo, then try to scan. Make sure the original document or photo is in good condition and free of tears, creases, folds, staples, or tape.
If the issue persists, continue to the next step.
Printers with a document scan feeder
Clean the plastic and glass strips inside the document feeder with a soft, lint-free cloth sprayed with glass cleaner.
Some printers ship with a document feeder cleaning cloth. If you have the cloth, load it into the document feeder and start a scan job to clean the scanner mechanism.
Turn the printer off, disconnect the power cord, and remove the battery if your printer has one.
Depending on your printer model, open any top cover, document feeder tray, and scan document feeder cover.
Remove any debris such as bits of paper or paper clips from inside the document feeder.
Spray a soft, lint-free cloth with glass cleaner, then wipe the scanner glass and the white strip on the underside of the document feeder until clean, dry, and streak-free.
To protect the interior printer parts, do not spray the cleaner directly on or into the printer.
Completely close any covers and trays that you opened.
Reconnect the power cord, reinstall the battery if necessary, then turn on the printer.
