    Think you need a hardware repair or want to check repair status? Try our HP repair center
    Fix HP Printer issue on macOS
Adding or Replacing Memory for HP Envy Recline 23 TouchSmart All-in-One PCs
This document applies to HP Envy Recline 23 TouchSmart All-in-One computers.
Before you begin
  • Have a Phillips head screwdriver ready .
  • Turn off the computer, disconnect the Ethernet or modem cable, and Disconnect the power cord.
  • Transfer the computer to a clean, flat, stable work surface over a noncarpeted floor. HP recommends putting down a blanket, towel, or othersoft cloth to protect the screen from scratches or other damage.
  • Use an antistatic wrist strap and a conductive foam pad when working on the computer.Electrostatic discharge (ESD) can damage your processor, disk drives, expansion boards and other components. HP strongly recommends the use of the wrist strap and conductive foam pad.
  • Remove a component from its protective packaging only when you are ready to install it.
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Removing the memory
Use the following steps to remove the memory:
Step 1
Remove the access door.
For instructions to remove the access door, see the HP support document, Removing and Replacing the Access Door.
Removing the access door
Step 2
Remove the memory cover by squeezing the release latch for the memory cover until the memory cover pops up.
You might need to press the memory cover down at the same time to get it to release.
Releasing the memory cover
Step 3
Remove the memory cover.
Removing the memory cover
Step 4
To remove the SO-DIMM memory module, gently pull out on the retaining lever located on each side of the module.
The memory module will pop up from its socket.
Opening the retaining levers
Step 5
Pull the memory module out of the socket.
Removing the memory module
Replacing the memory
Use the following steps to replace the memory:
Step 1
Find the small notch on the side of the memory module.
Finding the notch on the memory module
Step 2
Find the small tab on the side of the memory socket.
Finding the tab on the memory socket
Step 3
To replace a memory module, angle the module to about 45 degrees and engage the notch on the module with the tab in the socket.
Inserting the memory into the socket
Step 4
Press the memory module down into place until the retaining levers snap into position over the sides of the module.
Pressing the memory module into place
Step 5
Find the two tabs on the memory cover...
...and then find the two slots in the computer.
Replacing the shield
Step 6
Align the tabs into their slots and press the other side of the memory cover down firmly until the green release latch snaps into place to secure the cover.
Replacing the memory cover
Step 7
Replace the access door.
For instructions to replace the access door, see the HP support document, Removing and Replacing the Access Door.
Replacing the access door
Country/Region: Flag United States
