From the control panel, you can cancel print jobs, make copies, send faxes, and view the toner cartridge status and network connection status.
Only the HP Color LaserJet Pro MFP M181fw supports faxing.
Figure : Control panel buttons, icons, and lights
1. 2-line display: Displays function menus and printer information.
2.
Left arrow button: Navigate menus or decreases a value, such as number of copies.
3. OK button: Open control panel menus or confirms a menu selection.
4.
Right arrow button: Navigate menus or increases a value, such as number of copies.
5.
Cancel button: Cancels a print job, resets copy settings, or exits Copy Default Setting mode.
6.
Start Mono Copy button: Starts a black and white or grayscale copy job.
7.
Start Color Copy button: Starts a color copy job.
8.
Number of copies button: Set the number of copies.
9.
Lighter/Darker button: Lighten or darken copies.
10.
Copy Menu button: Open the Copy menu.
11. Alphanumeric keypad: Enter the number of copies or fax numbers.
12.
Fax Redial button: Redial the last fax number.
13.
Start Fax button: Starts a fax job.
14.
Setup button: Opens the Setup menu.
15.
Wireless button: Opens the Wireless menu.
16.
Back button: Exit a menu or return to a previous menu.
17.
Ready light: Indicates the printer is ready to print, is receiving print data, or is canceling a print job.
18.
Attention light: Indicates the printer requires user attention.
