This document is for HP DeskJet 1110, 1111, 1112, 1210, 1212, 1255, DeskJet Ink Advantage 1115, 1118, 1216, and 1275 printers.
Replace ink cartridges that are low or out of ink with new, genuine HP ink cartridges.
caution:Do not touch the copper-colored contacts or the ink nozzles. Do not replace the protective tape on the contacts. Handling these parts can result in clogs, ink failure, and bad electrical connections.
note:The printer only prints an alignment page automatically when new ink cartridges are installed.
