This document is for HP printers and Android, Apple iOS, and iPadOS smartphones and tablets.
Use HP Smart for mobile devices to print, copy, scan, troubleshoot printer issues, and set up a printer on a wireless network.
An HP account might be required to use some HP Smart features. If you do not have an account, you can create one during the software installation process.
note:This document is for the HP Smart app on Android, iOS, and iPadOS mobile devices. If you are using a Windows 10 computer or a Mac, go to Install and Use the HP Smart App (Windows 10) or Install and Use the HP Smart App (Mac).
