Підтримка користувачів НР - База знань
Дії
Завантаження...
Дії
Завантаження...
  • Інформація
    Дізнайтесь, як перейти на Windows 11
    Посібник з оновлення Windows 11
    Інформація
    The website is under updating / веб-сайт оновлюється
  • Відгук
HP Deskjet 6540 Series Printers - Removing and Installing Print Cartridges
Step 1 - Open the printer
  1. Make sure the printer is turned on. Press the Power button if it is not lit.
    Figure : Press the Power button if it is not lit
  2. Open the printer cover, then wait until the print cartridge cradle is idle and silent.
Figure : Opening the printer
Cartridge replacement animation
Click the play button above () to see an animation on how to replace print cartridges, or continue to the sections below for detailed instructions.
Step 2 - Remove old cartridges
  1. Press down lightly on top of the cartridge latch.
  2. Pull out the bottom of the latch to unhook it.
  3. Slide the cartridge out.
    Figure : Open the cartridge latch
    Figure : Slide the cartridge out
Step three: Use a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
Figure : Insert a cartridge into a cartridge protector
Figure : To remove, press down on the latch
Step 4 - Make sure the new cartridges are compatible
Step 5 - Install the new cartridges
  1. If you are installing a new print cartridge, remove the protective tape.
    Do not attempt to remove the copper strip.
    Figure : Remove the protective tape
    After the tape is removed, do not touch the copper contacts or the ink nozzles.
      Figure : Contacts and nozzles
    1. Contacts
    2. Nozzles
  2. Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
    Figure : Put each cartridge into the proper slot
  3. Push down on the print cartridge latch until it snaps closed.
    Figure : Slide the print cartridge in
    Figure : Close the latch
  4. Close the printer cover.
Країна/Регіон: Flag Україна
Дії
Завантаження...
