İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
  • Bilgi
    Windows 11
    Yaygın soruları ve yanıtlarını burada bulabilirsiniz.
  • Geri Bildirim
İşlemler
Yükleniyor...
HP OfficeJet Pro 9010, 9020 Printers - First Time Printer Setup
This document is for HP OfficeJet Pro 9010, 9010e, 9012, 9013, 9014, 9014e, 9015, 9015e, 9016, 9018, 9018e, 9019, 9020, 9020e, 9022, 9022e, 9023, 9025, 9025e, 9026, 9028, OfficeJet 9012, 9012e, and Premier All-in-One printers.
To set up a printer for the first time, remove the printer from the box, connect the power cord, install the ink cartridges, load paper, and then align the printhead.
not:
If you are looking for the printer software, go to 123.hp.com.
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  2. Remove the film from the printer control panel.
    Removing tape from the printer
  3. Lift the scanner lid, remove the packing material from the scanner glass, and then close the scanner lid.
    Remove packing material from scanner bed
  4. Recycle the packing materials.
Step 2: Connect the power cord and set your preferences
Plug the printer into an electrical outlet, turn on the printer, and then set your preferences.
not:
  1. Connect the power cord to the rear of the printer, then plug the other end of the power cord into an electrical outlet.
    Connecting the power cord
  2. If the printer does not turn on automatically, press the Power button.
  3. To set your preferences on the printer control panel, touch your preferred language, and then touch Confirm.
  4. Touch your country/region.
Install the HP ink cartridges that shipped in the box with your printer.
  1. Open the front door, and then lift the ink cartridge access door.
    The carriage moves to the center of the printer.
    Opening the ink cartridge access door.
  2. Wait until the carriage stops moving before you continue.
  3. Remove the ink cartridges from the box, and then remove the film from the ink cartridges. Be careful to only touch the black plastic on the ink cartridge.
    Remove cartridges from box
  4. Insert the ink cartridges into their slots.
    Inserting the ink cartridges.
  5. Close the front door and ink cartridge access door.
    Closing the ink cartridge access door.
  6. On the printer control panel, touch OK.
Load plain, U.S. letter, or A4 paper in the input tray, and then align the printhead with an automated tool.
  1. Pull out the input tray, and then remove the packing materials.
    Opening the input tray
  2. Load plain white paper into the input tray with the short edge forward and the print side down.
    Loading paper in the input tray
  3. Slide in the paper width guides in until they rest against the edges of the paper.
    Sliding in the paper width guides
  4. Insert the input tray into the printer.
    Reinserting the input tray
  5. On the printer control panel, touch OK.
  6. Align the printhead.
    • If there is a prompt to align the printhead, touch OK to continue with the alignment.
    • If there is no prompt to align the printhead, select Align Printhead from the Setup menu on the control panel.
    An alignment page prints.
  7. Open the scanner lid, and then place the alignment page on the scanner glass. Place the page face down with the top of the page aligned to the engraved guides near the back corner of the glass.
    Placing the alignment page on the scanner glass
  8. Close the scanner lid, and then touch Scan.
    The printer scans the alignment page, and an Alignment Successful message displays on the control panel.
Step 5: Install the printer software
Your HP printer hardware is now set up, and you can install the printing software. Do not attempt to connect the printer to a computer until instructed to do so during software installation.
Download the latest version of the printing software from 123.hp.com.
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Ülke/Bölge: Flag Türkiye
İşlemler
Yükleniyor...
