The image on the wireless display does not fill the entire screen; it is centered and surrounded by black borders. This occurs when using Microsoft Wireless Display if the picture size is set to less than 100% (the default is 85%).
not:Connection must be established with the wireless display before viewing the Wireless Display tab.
not:Once this option has been changed, it will remain unless manually changed again.
