Load plain paper, such as A4, U.S. letter, or U.S. legal, into the main or priority input tray.
Load plain paper in the main input tray
Load plain paper into the main input tray.
Lower the main input tray door.
Slide out the paper guides as far as possible.
Load up to 250 sheets of paper with the print side facing up and the top edge toward the printer. If you are loading pre-punched paper, load the paper with the holes toward the left side of the tray.
Slide in the paper guides until they touch the edge of the stack of paper.
If you have loaded A4 or U.S. letter-size paper, close the main input tray door. Verify from the paper-stack
window for proper loading.
not:
Before printing or copying, select the correct paper size and paper type settings from the control panel or computer.
Load plain paper in the priority input tray
Load plain paper into the priority input tray.
Lower the main priority input door.
Slide out the paper width guides as far as possible.
Load up to 10 sheets of plain paper with the print side facing up and the top edge toward the printer. If you are loading pre-punched paper, load the paper with the holes toward the left side of the tray.
Slide in the paper guides until they rest against the edges of the stack of paper.
