HP Desktop PCs - Motherboard Specifications, (Hawaii-KU)
Şekil : Hawaii-KU motherboard
Motherboard description
HP name: Hawaii-KU
SSID: 82DD
Form Factor
Customized: 20.0x14.5 cm (7.9x5.7 in)
The chipset on this motherboard is combined with the processor into a single integrated circuit called System on a Chip (SoC). This technology combines the processor and chipset functionality into a single physical package.
Processor upgrade information
Supports the Intel Core i3-7100U and Intel Core i5-7200U (Kabylake) Dual Core processors only. The processor is not upgradeable.
Memory upgrade information
Dual channel memory architecture
Two DDR4 SODIMM (260-pin) sockets
Supports up to PC4-17000 (DDR4-2133)
Supports 4 GB and 8 GB DDR4 SODIMMs (on Prost 24 chassis)
Supports 2 GB, 4 GB, and 8 GB DDR4 SODIMMs (on Prost 215 and 195 chassis)
Supports up to 4 GB on 32-bit systems
not:
32-bit systems cannot address a full 4.0 GB of memory.
Supports up to 16 GB (unbuffered) on 64-bit systems
not:
Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
