not:Trial license is associated to one or more printers connected to SmartStream. Trial can only be activated once by printer. It is a must to Print from SmartStream to a printer to have PostScript license. You will be able to install the 60 days trial version of SmartStream into a non-PostScript unit and that will enable the possibility to add this printer into the application and explore its features, however, when sending to print, jobs will be automatically cancelled as the printer does not have PostScript license.
- Step 1: Install HP SmartStream software
- Step 2: Configure a printer
- Step 3: Activate the trial period
1- Install HP SmartStream software.
Dowload SmartStream software and execute the installation package in the computer you want to use SmartStream and follow the wizard instructions. This step have to be done in every computer where you want to use SmartStream.
2- Configure a printer.
After upgrading your printer to latest firmware version that you can download it here by selecting your printer model. To connect to SmartStream, your printer have to be installed a HP SmartStream trial firmware upgrade that you can download here.
3- Activate the trial period.
The first time you start up SmartStream the software will ask to participate in customer involvement program, after this the license activation screen will appear, you have to select trial in order to start the 60 days trial period, then you will be asked to enter your Pinter host name or IP address. After that you will have 60 days of full HP SmartStream license. To purchase a full version you have to contact your HP partner.
