İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
  • Bilgi
    Windows 11'e Nasıl Yükselteceğinizi Öğrenin
    Windows 11'e Yükseltme Kılavuzu
  • Geri Bildirim
İşlemler
Yükleniyor...
HP 4500, 4600 Inkjet Printers - First Time Printer Setup
This document is for the following printers:
  • HP DeskJet Ink Advantage 4535, 4536, 4538, 4675, 4676, and 4678 All-in-One printers
  • HP ENVY 4510 (series), 4511, 4512, 4513, 4516, 4520, 4521, 4522, 4523, 4524, 4525, 4526, 4527, and 4528 All-in-One printers
  • HP OfficeJet 4650, 4652, 4654, 4655, 4656, 4657, and 4658 All-in-One printers
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the power cable, set control panel preferences, load paper into the input tray, install the ink cartridges, and then install the software.
not:
If you are looking for the printer software, go to 123.hp.com, type your printer model number, click Begin, and then click Download.
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  2. Remove all tape and packing materials from the outside of the printer.
    Şekil : Removing tape from HP DeskJet 4530, ENVY 4510, and 4520 printers
    Image: Removing tape from HP DeskJet 4530, ENVY 4510, and 4520 printers.
    Şekil : Removing tape from HP DeskJet 4670 and OfficeJet 4650 printers
    Image:  Removing tape from HP DeskJet 4670 and OfficeJet 4650 printers.
  3. Remove the sticker on the printer control panel.
  4. Gently grasp the handles on either side of the printer, raise the ink cartridge access door until it locks into place, and then remove all tape and packing material from inside the printer.
    Şekil : Removing packing materials from inside the printer
    Image: Removing packing materials from inside the printer.
  5. Close the ink cartridge access door.
    Şekil : Closing the ink cartridge access door.
    Image: Closing the ink cartridge access door.
  6. Open the input tray door, pull it toward you to extend the paper tray, and then remove the packing tape.
    Şekil : Opening the input tray and removing the tape
    Image: Opening the input tray and removing the tape.
  7. Push the input tray forward until it clicks into place to close the input tray door.
    Şekil : Closing the input tray
    Image: Closing the input tray.
  8. Recycle the packing materials.
Step 2: Connect the power cord and set your preferences
Plug the printer into a power source, turn on the printer, and then set your preferences.
not:
    Şekil : Connecting the power cord and power supply
    Image: Connecting the power cord and power supply
  2. Turn on the printer.
  3. To set your preferences on the printer control panel, touch your preferred language and country/region, and then touch Yes to confirm your choice.
  4. If prompted, select the date and time, and then touch Yes to confirm your choice.
Step 3: Load paper into the input tray
Load plain U.S. letter or A4 paper in the input tray.
  1. Open the input tray door, then pull it toward you to extend the paper tray.
    Image: Opening the input tray.
  2. Slide the paper width guides to their outermost position.
    Şekil : Adjusting the paper width guides
    Image: Adjusting the paper width guides
  3. Load a stack of U.S. letter, or A4 size paper into the paper tray with the short edge forward and the print side down.
    Şekil : Loading paper in the input tray
    Image: Loading paper in the input tray
  4. Push the stack into the tray until it stops.
  5. Slide in the paper width guides in until they rest against the edges of the paper, then push the input tray forward until it clicks into place.
    Şekil : Sliding in the paper width guides, then closing the input tray
    Image:  Sliding in the paper width guides, then closing the input tray.
Step 4: Install the ink cartridges
Install the HP ink cartridges that shipped in the box with your printer.
  1. Raise the ink cartridge access door until it locks into place.
    The carriage moves slightly to the left.
    Şekil : Opening the ink cartridge access door
    Image: Opening the ink cartridge access door.
  2. Wait until the carriage is idle and silent before you proceed.
  3. Remove one of the ink cartridges from its package. Be careful to only touch the black plastic on the ink cartridge.
    Şekil : Removing the ink cartridge from its package
    Image: Removing the ink cartridge from its package
  4. Remove the plastic tape from the ink cartridge.
      dikkat:
    Şekil : Removing the plastic tape
    Image: Removing the plastic tape
  5. Lift up the lid on the ink cartridge slot.
    Şekil : Lifting up the lid on the ink cartridge slot
    Image: Lifting up the lid on the cartridge slot
  6. Hold the ink cartridge by its sides with the nozzles toward the printer, and then press the ink cartridge forward into the slot until it snaps into place.
    Şekil : Inserting the ink cartridge
    Image: Inserting the ink cartridge.
  7. Close the lid on the ink cartridge slot to secure the ink cartridge into place.
    Şekil : Closing the lid on the ink cartridge slot
    Image: Closing the lid on the ink cartridge slot
  8. Repeat the previous steps to install the other ink cartridge.
      Şekil : Inserting the ink cartridges
      Image: Inserting the ink cartridges
    1. Insert the ink cartridge
    2. Close the lid
    3. The color ink cartridge is on the left, and the black ink cartridge is on the right
  9. Close the ink cartridge access door.
    • If the printer prints an alignment page, continue to the next step.
    • If the printer does not print an alignment page, touch Setup on the printer control panel. Select Tools, and then touch Align Printer. After the alignment page prints, continue to the next step.
Step 5: Align the ink cartridges
Aligning the ink cartridges is necessary to achieve the best print quality. Use the alignment page from the previous step to align the ink cartridges.
  1. Lift the scanner lid.
  2. Place the alignment page with the print side down on the scanner glass. Position it according to the engraved guides around the glass.
    Şekil : Place the alignment page on the scanner glass
    Image:
  3. Close the scanner lid, and then touch OK on the printer control panel.
    The printer aligns the ink cartridges.
Your HP printer hardware is now set up, and you can install the printing software. Do not attempt to connect the printer to a computer until instructed to do so in the printing software.
Download the latest version of the printing software. Go to 123.hp.com, type your printer model number, click Begin, and then click Download.
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Ülke/Bölge: Flag Türkiye
İşlemler
Yükleniyor...
