HP Printers - Control Panel Features
This document is for the following printers.
HP DeskJet Ink Advantage 3835 All-in-One Printer
HP ENVY 4520 All-in-One Printer
HP ENVY 5547 All-in-One Printer
HP DeskJet Ink Advantage 3836 All-in-One Printer
HP ENVY 4521 All-in-One Printer
HP ENVY 5548 All-in-One Printer
HP DeskJet Ink Advantage 3838 All-in-One Printer
HP ENVY 4522 All-in-One Printer
HP OfficeJet 3830 All-in-One Printer
HP DeskJet Ink Advantage 4535 All-in-One Printer
HP ENVY 4523 All-in-One Printer
HP OfficeJet 3831 All-in-One Printer
HP DeskJet Ink Advantage 4536 All-in-One Printer
HP ENVY 4524 All-in-One Printer
HP OfficeJet 3832 All-in-One Printer
HP DeskJet Ink Advantage 4538 All-in-One Printer
HP ENVY 4525 All-in-One Printer
HP OfficeJet 3833 All-in-One Printer
HP DeskJet Ink Advantage 4675 All-in-One Printer
HP ENVY 4526 All-in-One Printer
HP OfficeJet 3834 All-in-One Printer
HP DeskJet Ink Advantage 4676 All-in-One Printer
HP ENVY 4527 All-in-One Printer
HP OfficeJet 3835 All-in-One Printer
HP DeskJet Ink Advantage 4678 All-in-One Printer
HP ENVY 4528 All-in-One Printer
HP OfficeJet 4650 All-in-One Printer
HP DeskJet Ink Advantage 5575 All-in-One Printer
HP ENVY 5540 All-in-One Printer
HP OfficeJet 4652 All-in-One Printer
HP DeskJet Ink Advantage Ultra 5738 All-in-One Printer
HP ENVY 5541 All-in-One Printer
HP OfficeJet 4654 All-in-One Printer
HP DeskJet Ink Advantage Ultra 5739 All-in-One Printer
HP ENVY 5542 e-All-in-One Printer
HP OfficeJet 4655 All-in-One Printer
HP ENVY 4511 All-in-One Printer
HP ENVY 5543 All-in-One Printer
HP OfficeJet 4656 All-in-One Printer
HP ENVY 4512 All-in-One Printer
HP ENVY 5544 All-in-One Printer
HP OfficeJet 4657 All-in-One Printer
HP ENVY 4513 All-in-One Printer
HP ENVY 5545 e-All-in-One Printer
HP OfficeJet 4658 All-in-One Printer
HP ENVY 4516 All-in-One Printer
HP ENVY 5546 All-in-One Printer
The control panel contains buttons and icons to run the printer and a control panel display to select print options.
Control panel buttons and lights
From the control panel display, access the Home button, verify wireless connectivity, and access Help menus.
Şekil : Example of the control panel buttons, icons, and lights
Image: Example of the control panel buttons, icons, and lights
1. Power button: The button turns the printer on or off.
2. Home button: The button returns the control panel display to the Home screen, which is the screen that displays when you first turn on the printer. The button lights up when the feature is available.
3. Control panel display: Touch the screen to select menu options, or swipe your finger across the display to scroll through the menu items.
4. Wireless status light: The light indicates the status of the printer wireless connection. A solid blue light indicates that a wireless connection is established and that you can print wirelessly. If the wireless feature is turned off, the wireless light is off and the Wireless Summary screen displays Wireless Off.
5. Help button: The button opens the Help menu for the current operation. The button lights up when the feature is available.
6. Back button: The button returns to the previous screen. The button lights up when the feature is available.
Control panel display menu
Touch the control panel display to select print, fax, copy, and scan options from the main menu. Swipe your finger across the display to scroll through the menus.
Şekil : Example of the control panel display menus
Image: Example of the control panel display menus
The following list describes the functionality of each option:
1. Copy: The option opens the Copy menu to select a copy type or change the copy settings.
2. Scan: The option opens the Scan To menu to select a destination for your scan.
3. Fax: The option opens a screen to send a fax or change fax settings.
4. HP Printables: The option provides a quick way to access and print information from the web such as coupons, coloring pages, puzzles, and more.
5. Quick Forms: The option opens the Quick Forms menu where you can select a form to print.
6. Setup: The option opens the Setup menu to change preferences and use tools to perform maintenance tasks.
7. Help: The option opens the Help menu to view how-to videos, printer feature information, and tips.
8. HP ePrint icon: The option opens the Web Services Summary menu to check ePrint status details, change ePrint settings, or print a Web Services Information page.
9. Wireless Direct icon: The option opens the Wireless Direct Summary menu to turn on or off HP wireless direct printing and display the wireless direct name and password.
10. Wireless icon: The Wireless icon opens the Wireless Summary menu to check wireless status and change wireless settings. You can print a wireless test report to help diagnose network connection issues. If there is no network connection, the Wireless icon displays by default.
11. Ink icon: The option shows estimated ink levels by ink cartridge. The icon displays a warning symbol if the ink level is less than the minimum expected ink level.
12. Fax status icon: The option opens status information for the Auto Answer function, fax logs, and the fax sound volume.
