İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
  • Bilgi
    Windows 11'e Nasıl Yükselteceğinizi Öğrenin
    Windows 11'e Yükseltme Kılavuzu
  • Geri Bildirim
İşlemler
Yükleniyor...
HP LaserJet Pro 200 color MFP M276 Printer Series - Replacing the Toner Cartridges
Replace the toner cartridges
  1. Open the front door.
    Şekil : Open the front door
  2. Pull out the toner cartridge drawer.
    Şekil : Open the toner cartridge drawer
  3. Grasp the handle on the toner cartridge, and then pull the toner cartridge straight up to remove it.
    Şekil : Remove the old toner cartridge
  4. Remove the new toner cartridge from the packaging.
    Şekil : Remove the new toner cartridge from the packaging
  5. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge.
  6. Remove the plastic shield from the bottom of the new toner cartridge.
    Şekil : Remove the packing material
  7. Do not touch the imaging drum on the bottom of the toner cartridge. Fingerprints on the imaging drum can cause print-quality problems.
    Şekil : Do not touch the imaging drum
  8. Insert the new toner cartridge into the product.
    Şekil : Insert the new cartridge
  9. Pull the tab on the left side of the toner cartridge straight up to completely remove the sealing tape. Discard the sealing tape.
    Şekil : Remove the sealing tape
  10. Close the toner cartridge drawer.
    Şekil : Close the toner cartridge drawer
  11. Close the front door.
    Şekil : Close the front door
  12. Place the old toner cartridge and the plastic shield in the box for the new toner cartridge. Follow the recycling instructions that are included in the box.
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Ülke/Bölge: Flag Türkiye
İşlemler
Yükleniyor...
