İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Removing and Replacing the Back Covers in HP TouchSmart 610, 620 Series Desktop PCs
This document applies to HP Touch 610 and 620 all-in-one desktop computers.
HP TouchSmart 610 or 620 all-in-one desktop computer
Before you begin
  • Turn off the computer and disconnect all cables.
  • Transfer the computer to a clean, flat, stable work surface over a noncarpeted floor. HP recommends that you put down a blanket, towel, or other soft cloth to protect the screen from scratches or other damage.
  • Electrostatic discharge (ESD) can damage your processor, disk drives, expansion boards and other components. HP strongly recommends the use of an antistatic wrist strap and a conductive foam pad when working on the computer.
  dikkat:
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Video overview
Removing and replacing the back access panels
This document provides instructions to remove the back panels to permit access to the CD/DVD drive, the hard disk drive, and the system memory.
For specific instructions, click one of the following links:
  uyarı:
Removing and replacing the USB dongle cap
Use the following steps:
Removing the USB dongle cap
Step 1
Squeeze the release tabs for the rear I/O door.
Release tabs for the rear I/O door
Step 2
Swing out the rear I/O door until it locks into position.
Opening the rear I/O door
Step 3
Pull on the top edge of the USB dongle cap to remove it from the computer.
Removing the dongle cap from the computer
Replacing the USB dongle cap
Step 1
Find the two tabs on the bottom of the USB dongle cap.
The two tabs on the USB dongle cap
Step 2
Find the slots on the rear cover.
Releasing the retaining levers
Step 3
Align the two tabs onto their slots and press the cover into place.
Replacing the dongle cap
Step 4
Swing in the rear I/O door until it locks into position.
Pulling the SO-DIMM module out of the socket
Removing and replacing the right rear cap
Remove the right rear cap to access the hard disk drive and the CD/DVD drive.
Removing the right rear cap
Step 1
Remove the USB dongle cap.
Step 2
Pull off the screw cover at the top edge of the cap.
Removing the screw cap
Step 3
Remove the screw.
Removing the screw
Step 4
Slide the right rear cap towards the middle of the computer.
Sliding the cap to the center
Step 5
Pull off the cap.
Removing the cap
Replacing the right rear cap
Step 1
Find the tab on the top side of the right rear cap.
Tab on the top side of the right rear cap
...that slides under the screw hole on the rear cover.
Screw hole on the rear cover
Step 2
Find the tabs on the top edges ...
Tabs on the top edge of the cap
...and the bottom edges of the cap.
Tabs on the bottom edge of the cap
that slide into slots on the upper edge of the rear cover...
Slots on the upper edge of the rear cover
...and the lower edge of the rear cover.
Slots on the lower edge of the rear cover
Step 3
Slide the screw tab on the door under the hole on the frame.
Sliding the screw tab on the door under the hole on the frame
Step 4
Press the right rear cap down against the rear cover so the tabs align into their slots.
Pressing the right rear cap down against the rear cover
Step 5
Slide the cap towards the side...
Sliding the cap to the side
... until the screw hole on the cap and the rear cover align.
Aligning the screw hole
Step 6
Replace the screw.
Replacing the screw
Step 7
The screw cover has two small tabs...
Tabs on the screw cover
...that fit into slots on the rear cover.
Step 8
Press the screw cover tabs into the slots and snap the screw cover into place.
Step 9
Replace the USB dongle cap.
Removing and replacing the right side cap
Remove the right side cap to access the CD/DVD drive.
Removing the right side cap
Step 1
Step 2
Remove the right rear cap.
Step 3
Detach the two screws for the right side cap.
Removing the screws
Step 4
Use a flat head screwdriver to pry up the latch securing the cap to the rear cover.
Prying up the latch
Step 5
Rotate the cap off of the unit.
Removing the cap
Replacing the right side cap
Step 1
Find the slotted tabs...
Slotted tabs
...that fit into slots on the front bezel.
Slots on the front bezel
Step 2
Find the latch on the right side cap...
Latch on the right side cap
... that attaches over a slot on the rear cover.
Step 3
Align the slotted tabs over the slots on the bezel.
Aligning the tabs with the slots on the bezel
Step 4
Rotate the cap and press until the latch snaps into place.
Positioning the cap and pressing into place
Step 5
Press the cap edges to make sure it is correctly in place.
Pressing the cap edges
Step 6
Replace the two screws for the right side cap.
Replacing the screws
Step 7
Replace the right side cap and the USB dongle cap.
Removing and replacing the left rear cap
Remove the left rear cap to access the system memory.
Removing the left rear cap
Step 1
Step 2
Step 3
Remove the screw.
Removing the screw
Step 4
Slide the left rear cap towards the middle of the computer.
Step 5
Pull off the cap.
Removing the cap
Replacing the left rear cap
Step 1
Find the tab on the top side of the left rear cap.
Tab on the top side of the left rear cap
Step 2
Step 3
Step 4
Press the left rear cap down against the rear cover so the tabs align into their slots.
Press the left rear cap into place
Step 5
Aligning the screw holes
Step 6
Replace the screw.
Replacing the screw
Step 7
Slots on the rear  cover
Step 8
Step 9
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Ülke/Bölge: Flag Türkiye
İşlemler
Yükleniyor...
