İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
  • Bilgi
    Windows 11
    Yaygın soruları ve yanıtlarını burada bulabilirsiniz.
  • Geri Bildirim
İşlemler
Yükleniyor...
HP Printers - Bluetooth Guide for HP Printers
This document is for HP printers that support Bluetooth printing.
Bluetooth is available with some HP printers as a wireless printing option. Review the following Bluetooth printer compatibility lists, and then set up the connection to start printing.
For information on Bluetooth Smart, go to Bluetooth Smart (Bluetooth Low Energy) and HP Printers.
Printers with built-in Bluetooth
Certain HP printers have a built-in Bluetooth radio that supports pairing with a computer, mobile phone, or tablet to enable wireless printing.
  1. Turn on the Bluetooth radio on the printer. Depending on the model, press the Bluetooth button , or navigate to the Setup or Network menu to access Bluetooth settings.
  2. Open the Bluetooth settings on the computer or mobile device and confirm that the feature is enabled.
  3. Wait for the printer name to display in the list of discoverable devices, and then select the printer to confirm that you want to pair the devices.
  4. Open a document or photo, open the Print menu, and then select your printer to print.
The following HP printers have a built-in Bluetooth radio.
HP Officejet 100 Mobile Printer (L411)
HP Photosmart C8180, C8183, C8188 Printers
HP Officejet 150 Mobile All-in-One Printer (L511a)
HP Photosmart Premium All-in-One Printers (C309)
HP Photosmart A646 Compact Photo Printer
Printers that require an adapter for Bluetooth printing
Some HP Deskjet, Officejet, and Photosmart printers released in 2008 and earlier support Bluetooth printing with a separately purchased Bluetooth adapter. Supported printers and HP Bluetooth adapters, such as the bt300 or bt500, are no longer available for purchase from HP. If you own a supported printer but do not have the adapter, you still might locate one through an online auction or retail website.
Example of an HP Bluetooth adapter
If you have a compatible adapter, insert it in into the USB or Pictbridge port that is typically on the front or side of the printer. Make sure the HP driver and software is installed (if you are printing from a Windows or Mac computer), and then pair the printer through the Bluetooth settings on the computer or mobile device.
Examples of inserting the HP Bluetooth adapter into the USB or Pictbridge port on the front or side of the printer
The following HP printers support printing over a Bluetooth connection with an adapter.
HP Deskjet 450, 460 Mobile Printers
HP Photosmart 8400 Printers
HP Deskjet 6940, 6980 Printers
HP Photosmart 8450 Photo Printers
HP Officejet 6300 Printers
HP Photosmart A310 Printers
HP Officejet 7200, 7300, 7400 Printers
HP Photosmart A430 Printers
HP Officejet H470 Mobile Printers
HP Photosmart A510 Printers
HP Officejet J6480 All-in-One Printer
HP Photosmart A512, A516, A530 Photo Printers
HP Officejet Pro 8500 Printers (A909)
HP Photosmart A610, A620, A630 Photo Printers
HP Officejet Pro L7500, L7650, L7680, L7780 Printers
HP Photosmart A710 Photo Printers
HP Photosmart 320, 330, 370, 380 Printers
HP Photosmart A820 Home Photo Center
HP Photosmart 420, 470, 475 Printers
HP Photosmart C5100, C5200, C5300, C5500 Printers
HP Photosmart 2600, 2700 Printers
HP Photosmart C6100, C6200, C6300 Printers
HP Photosmart 3100, 3200, 3300 Printers
HP Photosmart C7100, C7200 Printers
HP Photosmart 7830, 7850 Printers
HP Photosmart D5160, D5163 Printers
HP Photosmart 8030, 8050 Printers
HP Photosmart D7100, D7200, D7300, D7400, D7560 Printers
HP Photosmart 8150 Photo Printer
HP Photosmart Plus All-in-One Printer (B209)
HP Photosmart 8238, 8250 Printers
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Ülke/Bölge: Flag Türkiye
İşlemler
Yükleniyor...
