İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
  • Bilgi
    Windows 11'e Nasıl Yükselteceğinizi Öğrenin
    Windows 11'e Yükseltme Kılavuzu
  • Geri Bildirim
İşlemler
Yükleniyor...
HP LaserJet Pro P1566 and P1606dn Printers - Setting Up the LaserJet (Hardware)
This document includes the following steps to set up the printer:
  • Remove packing tape
  • Prepare the print cartridge
  • Prepare the trays
  • Load plain paper
  • Connect the power cord
  • Turn on power
Setting up the printer
Follow these steps in order.
Step one: Check the contents of the box
Remove the printer from the box, and then check the contents of the box.
Step two: Remove packing tape
Remove all packing tape from the printer.
Step three: Prepare the print cartridge
  1. Open the print cartridge door.
    Şekil : Open the print cartridge door
    Illustration: Open the print cartridge door.
  2. Lift up the paper packing, but do not remove it.
    Şekil : Lift the paper packing
    Illustration: Lift the paper packing.
  3. Remove the print cartridge packaging.
    Şekil : Remove the print cartridge packaging
    Illustration: Remove the print cartridge packaging.
  4. Remove the print cartridge from the printer.
    Illustration: Remove the print cartridge.
      dikkat:
    To prevent damage to the print cartridge, hold the print cartridge at each end.
  5. Remove the packaging from inside the printer.
    Şekil : Remove the packaging from inside the printer
    Illustration: Remove the packaging from inside the printer.
  6. Remove the orange clip from the end of the print cartridge.
    Şekil : Remove the orange clip from the print cartridge
    Illustration: Remove the orange clip from the print cartridge.
  7. Gently rock the print cartridge back and forth to distribute the toner evenly.
    Şekil : Rock the print cartridge
    Illustration: Rock the print cartridge.
  8. Bend the tab on the left side of the print cartridge until the tab breaks loose. Pull the tab to remove all the sealing tape from the print cartridge.
    Şekil : Remove the sealing tape
    Illustration: Remove the sealing tape.
      dikkat:
    If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
  9. Insert the print cartridge, and then close the print cartridge door.
    Şekil : Insert the print cartridge and close the door
    Illustration: Insert the print cartridge and close the door.
Step four: Prepare the trays
  1. Insert the output tray.
    Şekil : Insert the output tray
    Illustration: Insert the output tray.
  2. Insert the priority input tray.
    Şekil : Insert the priority input tray
    Illustration: Insert the priority input  tray
Step five: Load plain paper
  1. Raise the priority input tray, and then slide the paper length and width guides to their outermost positions.
    Şekil : Slide out paper guides
    Illustration: Slide out paper guides.
  2. Load plain paper in the main input tray with the top forward and the print side up.
    Şekil : Load paper
    Illustration: Load paper into the main input tray.
  3. Slide the paper guides inward so that they rest against the stack of paper.
    not:
    To prevent jams and skewing, always adjust the side and front paper guides.
    Şekil : Adjust the paper guides
    Illustration: Adjust the paper guides
  4. Lower the priority tray.
    Şekil : Lower the priority tray
    Illustration: Lower the priority tray.
Step six: Connect the power cord
  1. Connect the power cord to the back of the printer.
    Şekil : Connect the power cord
    Illustration: Connect the power cord to back of printer
  2. Plug the power cord into an electrical outlet.
Step seven: Turn on power
Press the Power button to turn on the printer.
Şekil : Turn on the power
Illustration: Turn on the power.
not:
A blank page might print when you turn on the printer for the first time.
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Ülke/Bölge: Flag Türkiye
İşlemler
Yükleniyor...
