İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
HP Deskjet F2400 All-in-One Printer Series - Setting up the All-in-One Parts (Hardware)
  • Unpack the All-in-One
  • Connect the power cord and adapter
  • Turn on power
  • Load plain paper
  • Install the cartridges
  • Align the cartridges
Follow these steps in order.
  1. Remove the tape from the outside of the product, and then open it. Be sure to remove and discard the orange shipping lock.
  2. Lower the paper tray.
  3. Open the front access door, and then remove the packing material from the inside of the product, including the packing material inside the door.
    Şekil : Unpack the All-in-One
    Illustration of removing the packing material.
  4. Close the front access door.
    Şekil : Close the front access door
    Illustration of the front access door  closing.
Step three: Connect the power cord and adapter
  1. Plug one end of the power cord into the back of the product.
  2. Plug the other end into a grounded wall outlet.
Şekil : Connect power cord and adapter
Illustration of connecting power cord and adapter.
Step four: Turn on power
Press the Power button to turn the product on.
Şekil : Turn on the product
Illustration showing location of the power button.
Step five: Load plain paper
  1. Lower the paper tray.
  2. Lift out the paper tray extension.
    Şekil : Lift out the paper tray extension
    Illustration of lifting out the paper tray extension
  3. Slide the paper width guide all the way to the left.
  4. Load a stack of 216 x 279 mm (8.5 x 11 inch) plain paper into the paper tray, print-side down. Slide the stack of paper forward until it stops.
    Şekil : Load paper
    Image of loaded paper.
  5. Slide the paper width guide snugly against the paper.
Step six: Install the cartridges
  1. Press the Power button () to turn on the product, if it is not already turned on. Wait until the product is idle and silent before continuing.
  2. Open the front access door.
    The carriage moves to the center of the product. Wait until the carriage is idle and silent before continuing.
    Şekil : Open the front access door
    Illustration of the front access door opened.
  3. Remove the new cartridge from its packaging, and then carefully remove the plastic tape using the pink pull tab.
      dikkat:
    Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the cartridges. Doing so can result in clogs, ink failure, and bad electrical connections.
      Şekil : Remove the plastic tape
      Illustration of removing the tape from the new cartridge
    1. Copper-colored contacts
    2. Plastic tape with pink pull tab (must be removed before installing)
    3. Ink nozzles under tape
  4. Hold the cartridge by its sides with the nozzles toward the product, and then insert the cartridge into its color-coded slot until it snaps into place. Make sure that the icon on the cartridge matches the icon on the slot.
    Şekil : Example of inserting the tri-color cartridge
    IIllustration of reinserting the cartridge
    • Insert the tri-color cartridge in the slot on the left.
    • Insert the black cartridge in the slot on the right.
    Şekil : Color-coded cartridge slots
    Illustration of the cartridges and their slots.
  5. Repeat these steps for the other cartridge.
  6. Close the front access door. An alignment page prints automatically. Wait until the page prints before continuing.
    Illustration of closing the front access door.
Step seven: Align the cartridges
  1. Lift the product lid.
    Şekil : Lift the product lid
    Illustration of lifting the product lid
  2. Place the alignment page with the printed-side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment page.
    Şekil : Place the alignment page on the scanner glass
    Illustration  of alignment page on the scanner glass.
  3. Lower the product lid.
    Şekil : Lower the lid
    Illustration of lowering the product lid
  4. Press Start Copy Color to start the alignment.
  5. When the cartridge alignment is complete, recycle or discard the alignment page.
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Ülke/Bölge: Flag Türkiye
İşlemler
Yükleniyor...
