İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
  • Bilgi
    Windows 11'e Nasıl Yükselteceğinizi Öğrenin
    Windows 11'e Yükseltme Kılavuzu
  • Geri Bildirim
İşlemler
Yükleniyor...
HP Officejet 4400 (K410), Deskjet Ink Advantage (K209), and Deskjet F4400 All-in-One Printer Series - Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Connect the power cord and adapter
  • Load plain white paper
  • Install the cartridges
  • Align the cartridges
Follow these steps in order.
  1. Lift the product out of its box.
  2. Remove all tape from the paper tray, and then open the front access door.
    Şekil : Remove tape from paper tray
    Remove packing materials.
  3. Remove the packing material from inside the front access door.
    Şekil : Remove packing material
  4. Close the front access door.
    Şekil : Close the front access door
Step three: Connect the power cord and adapter
  1. Turn the product to access its rear side.
  2. Plug the power cord into the rear of the product.
    Şekil : Connect the power cord to the rear of the product
  3. Connect the power cord to the power adapter.
    Şekil : Connect the power cord to the power adapter
  4. Plug the other end of the power cord into an electrical outlet.
    Şekil : Connect the power cord to the electrical outlet
    Connect power cord
  5. Press the Power button () to turn on the product.
    Şekil : Turn on the product
    Turn on the product
Step four: Load plain white paper
  1. Pull out the paper tray extender.
    Şekil : Pull out the paper tray extender
  2. Pull out the paper stop at the end of the paper tray extender.
    Şekil : Pull out the paper stop
  3. Slide the paper-width guide to its outermost position.
    Şekil : Slide the paper-width guide to its outermost position
  4. Load a stack of plain white paper into the paper tray with the short edge forward and print side down. Push the paper forward until it stops.
    Şekil : Load paper
    Load paper
  5. Adjust the paper-width guide so it rests against the stack of paper.
    Şekil : Adjust the paper-width guide
Step five: Install the cartridges
  1. Make sure the product is on.
  2. Open the front access door.
    Şekil : Open the front access door
  3. Remove one of the cartridges from its packaging, and then pull the pink pull-tab to remove the protective tape from the nozzles.
    Şekil : Remove the protective tape
      dikkat:
    Do not touch the cartridge contacts or nozzles.
    Şekil : Do not touch the contacts
  4. Hold the cartridge by its sides.
    Şekil : Hold the cartridge by its sides
  5. Insert the cartridge into its designated slot. The black parallelogram icon () designates the slot for the black cartridge, and the magenta half circle icon () designates the slot for the color cartridge.
    Şekil : Insert cartridge
    Insert cartridge
    The cartridge rests in its slot at a slight upward angle.
    Şekil : Cartridge rests at upward angle
  6. Press the cartridge in to snap it into place.
    Şekil : Snap cartridge into place
  7. Repeat these steps to insert the other cartridge into its designated slot.
  8. Close the front access door.
Step six: Align the cartridges
  1. Wait while the product starts an automatic alignment process, and then prints an alignment sheet. The alignment process takes about 30 to 60 seconds to complete.
    Şekil : Product prints an alignment sheet
    Alignment sheet prints
    not:
    If the product does not automatically start the alignment process, disconnect the power cord from the rear of the product, and then plug it back in.
  2. Lift the product lid.
    Şekil : Lift the product lid
  3. Place the alignment sheet on with the printed side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment sheet.
    Şekil : Load the alignment sheet
  4. Lower the product lid.
    Şekil : Lower the lid
    Lower the lid
  5. Press the Scan button () to scan the alignment sheet.
    Şekil : Scan the alignment sheet
  6. Wait while the product scans the alignment sheet and completes the alignment process.
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Ülke/Bölge: Flag Türkiye
İşlemler
Yükleniyor...
