Follow these steps in order.
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
HP Officejet 6500 All-in-One Printer Series (E709) - Setting up the All-in-One (Hardware)
Follow these steps to unpack the product.
Remove all tape and packing materials outside the product.Şekil : Remove outer packing materials
Lift the product lid, and then remove all tape and packing materials inside the product and on the paper tray.Şekil : Remove packing materials from inside product and paper tray
Remove all tape and packing materials from the rear of the product.Şekil : Remove packing materials from the rear of the product
Step two: Attach the control panel faceplate
If the control panel faceplate is not already installed, follow these steps to install it.
Find the faceplate in the box, and then remove it from its packing material.Şekil : Control panel faceplate
Hold the faceplate above the product, and then position it so it fits over the buttons.
Press down on the faceplate to snap it into place.Şekil : Snap the faceplate into place
Step three: Install the two-sided printing accessory (duplexer)
If your model includes a two-sided printing accessory (duplexer), follow these steps to install it.
Find the duplexer in the box, and then remove it from its packing material. Remove any tape from the duplexer.Şekil : Duplexer
Turn the product to access its rear side.
Hold the duplexer by its sides with the rollers toward the product, and then insert it into the slot on the rear of the product.
not:
Look for the engraved arrows on the duplexer for help positioning it.Şekil : Insert the duplexer -
Push the duplexer into the product until it snaps into place.Şekil : Snap the duplexer into place
Step four: Connect the power cord
Plug the power cord into the rear of the product.Şekil : Connect the power cord to the rear of the product
Connect the power cord to the power supply.Şekil : Connect the power cord to the power supply
Plug the other end of the power cord into an electrical outlet.Şekil : Connect the power cord to the electrical outlet
Step five: Load plain white paper
Lift the output tray.Şekil : Lift the output tray
Insert the stack of paper print-side down along the right side of the paper tray.
Adjust the paper-width guide so it rests against the edge of the paper.Şekil : Adjust the paper-width guide
Close the output tray.
Pull out the extension on the output tray, and then open the paper catch at the end of the output tray extension.
Open the paper catch
Şekil : Open the output tray extension -
Step six: Turn the All-in-One on
Press the Power button (
) to turn on the product.
Şekil : Turn on the product
Step seven: Set the control panel language
If the language on the control panel defaults to a language other than what you prefer, follow these steps to set it.
Press the Setup button (
) repeatedly until Preference displays, and then press OK.
Press OK to select Set Language & Country/Region.
Press the Right Arrow button (
) until the desired language displays, and then type the associated numbers on the keypad.
Press 1 to accept the language setting.
Step eight: Install the printhead
Follow these steps to install the printhead.
Şekil : Printhead that shipped in the box
Open the cartridge access door.Şekil : Open the cartridge access door
Lift the gray latch on the printhead assembly.Şekil : Lift the gray latch
Remove the printhead from its packaging.Şekil : Remove printhead from its packaging
dikkat:
Do not touch the copper-colored contacts. Do not let the contacts touch any surface and be careful not to scratch the contacts while inserting the ink cartridges. -
Hold the printhead upright, with the color-coded icons facing up.Şekil : Hold the printhead upright
Lower the printhead into the product so that the purple and green blocks on the printhead align with the purple and green blocks on the product.Şekil : Insert the printhead
Slowly lower the gray latch.Şekil : Lower the gray latch
Step nine: Install the cartridges
Follow these steps to install the cartridges.
Şekil : Cartridges that shipped in the box
On one of the cartridges, pull the orange pull-tabstraight back to remove the plastic wrap.Şekil : Remove the plastic wrap
Twist the orange cap counterclockwise to snap it off the cartridge.Şekil : Remove the orange cap
With the cartridge contacts facing the printhead, slide the cartridge into the correct slot. The color-coded icons on the cartridge and in the printhead indicate the correct slot.Şekil : Insert the cartridge
Press down on the cartridge until it clicks firmly into place.Şekil : Press the cartridge into place
Repeat these steps for each cartridge.
Close the cartridge access door. The carriage moves to the right side of the product.
Wait for the product to align the cartridges and print an alignment page. This process takes about 10 minutes.Şekil : Example alignment page
not:
Mechanical noises during alignment are normal.
Ek destek seçenekleri
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
Ülke/Bölge:
Türkiye
- ${title}
Yükleniyor...
hp-hero-support-search
- ${title}
Yükleniyor...
