İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
  • Bilgi
    Windows 11
    Yaygın soruları ve yanıtlarını burada bulabilirsiniz.
  • Geri Bildirim
İşlemler
Yükleniyor...
HP Photosmart Pro B8850 Printer - Replacing Ink Cartridges
This document describes how to replace an ink cartridge.
Replacing ink cartridges
Follow these steps to replace ink cartridges.
  1. Open the ink cartridge door by pressing the raised bumps at the top of the door until the door clicks open.
    Şekil : Opening the ink cartridge door
  2. Remove the ink cartridge that needs to be replaced. Grasp a cartridge and pull it out of the stall.
  3. Shake the new ink cartridge vigorously, at least six times, before opening the package.
    Şekil : Shaking the ink cartridge
  4. Unwrap the ink cartridge and insert it into the correct stall. Press firmly on the cartridge to ensure proper contact.
    Şekil : Inserting the cartridge into its color-coded stall
  5. Close the ink cartridge door.
    Şekil : Closing the ink cartridge door
not:
All eight cartridges and all four printheads must be correctly installed for the printer to work.
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
İşlemler
Yükleniyor...
Ülke/Bölge: Flag Türkiye
İşlemler
Yükleniyor...
