- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
HP Officejet 5600 All-in-One Printer Series- Setting up the All-in-One (Hardware)
Unpack the All-in-One
Check the contents of the box
Attach the control panel faceplate
Attach the trays and load paper
Connect the power cord and adapter
Connect the supplied phone cord
Select the language/region
Install the cartridges
Align the cartridges
Follow these steps in order.
Remove all tape and cardboard packing material from the outside and inside of the product.
Şekil : Remove all packing materials
Step three: Attach the control panel faceplate
The control panel faceplate must be in place for the product to work. If the control panel faceplate is not already attached, do the following:
Align the faceplate over the buttons on the top of the product.Şekil : Align the faceplate
Snap the faceplate firmly into place.
Step four: Attach the trays and load paper
Insert the tabs of the bottom tray into the product, and then lower the tray until it is flat.Şekil : Insert the bottom tray
Slide the paper adjuster to the left.Şekil : Slide the paper adjuster to the left
Insert plain white paper.Şekil : Load plain paper
Insert the top edge of the output tray into the light gray latches, and then lower it.Şekil : Attach the output tray
Open the paper tray extender.Şekil : Open the tray extender
Step five: Connect the power cord and adapter
Plug the printer end of the power adapter into the back of the product.
Plug the adapter end of the power cord into the power adapter.
Plug the remaining end of the power cord into a grounded wall outlet or surge protector.
Şekil : Connect the power cord and adapter
Step six: Connect the supplied phone cord
Connect one end of the supplied phone cord to the phone port on the left (1-LINE) and the other to a wall jack.Şekil : Connect the phone cord
On the HP All-in-One control panel, press the On button (
The green light flashes, and then becomes solid. This might take up to a minute.
Step seven: Select the language/region
When prompted, use the arrow keys to select your language, press OK, and then confirm.
When prompted, use the arrow keys to select your country/region, press OK, and then confirm.
Step eight: Install the cartridges
Lower the access door, and then wait for the carriage that holds the cartridges to move to the right side.Şekil : Lower the access doorŞekil : The carriage
- Pull the pink tab to remove the tape from both cartridges.
Copper-colored contacts
Plastic tape with pink pull tab (must be removed before installing)
Ink nozzles under tape
Şekil : Remove the tapedikkat:
Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.Şekil : Do not touch the electrical contacts or ink nozzles -
Slide each new cartridge forward into its empty slot, and then gently push on the upper part of the cartridge until it snaps into place.
Insert the tri-color cartridge into the left slot.
Insert the black or photo cartridge into the right slot.
Şekil : Insert the cartridges -
Close the access door.Şekil : Close the access door
Step nine: Align the cartridges
After you insert the cartridges, a message displays indicating that the product is ready for alignment.
Ek destek seçenekleri
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
Ülke/Bölge:
Türkiye
- ${title}
Yükleniyor...
hp-hero-support-search
- ${title}
Yükleniyor...
