Make sure the printer is turned on. Press the Power button if it is not lit.Şekil : Press the Power button if it is not lit
- Open the printer cover, then wait until the print cartridge cradle is idle and silent.
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
HP Deskjet 5740 Series Printers - Removing and Installing Print Cartridges
Step 1 - Open the printer
Şekil : Opening the printer
Step two: Remove old cartridges
Press down lightly on the end of each print cartridge to release it.
The tri-color print cartridge is on the left
The black or photo print cartridge is on the right
Şekil : Removing the tri-color cartridge -
Slide the cartridge out.
Step 3 - Use a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
Şekil : Insert a cartridge into a cartridge protector
Şekil : To remove, press down on the latch
Step 4 - Make sure the new cartridges are compatible
Step five: Install new cartridges
If you are installing a new print cartridge, remove the protective tape.
dikkat:
Do not attempt to remove the copper strip.-
Protective tape
Şekil : Removing the protective tapedikkat:
After the tape is removed, do not touch the copper contacts or the ink nozzles.-
Contacts
Nozzles
Şekil : Contacts and nozzles -
Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
Cartridges marked with a triangle go into the left carriage slot.
Cartridges marked with a square or pentagon go into the right carriage slot.
Şekil : Sliding the cartridge into the carriage -
Push the print cartridge forward until it clicks into place.Şekil : Pushing the cartridge into place
Close the printer cover.
Ek destek seçenekleri
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
- ${title}
Yükleniyor...
Ülke/Bölge:
Türkiye
- ${title}
Yükleniyor...
hp-hero-support-search
- ${title}
Yükleniyor...
