ฝ่ายสนับสนุนลูกค้า HP - ฐานความรู้
  • ข้อมูล
    เรียนรู้วิธีอัปเกรดเป็น Windows 11
    คู่มือการอัปเกรด Windows 11
  • ข้อเสนอแนะ
HP Color LaserJet Pro M252, M277 Printers - Replacing Toner Cartridges
This document is for HP Color LaserJet Pro M252n and M252dw, and Color LaserJet Pro MFP M277n and M277dw printers.
View the video and read the steps in this document to replace a toner cartridge.
Video overview
This video shows you how to replace a toner cartridge in the HP Color LaserJet Pro MFP M277dw.
Replace a toner cartridge
Follow these steps to replace a toner cartridge in your printer.
บันทึก
The printer in these images might not look exactly like your printer, but the steps are the same.
  1. Open the front door.
    รูปภาพ : Opening the front door
    Image: Open front door
  2. Grasp the blue handle on the toner cartridge drawer, and thenpull out the drawer.
    รูปภาพ : Pulling out the toner cartridge drawer
    Image: Pull out cartridge drawer
  3. Grasp the handle on the toner cartridge, and then pull thetoner cartridge straight up to remove it.
    รูปภาพ : Removing the toner cartridge
    Image: Remove toner cartridge
  4. Remove the new toner cartridge package from the box, andthen pull the release tab on the packaging.
    รูปภาพ : Pulling the release tab on the packaging
    Image: Pull the release tab
  5. Remove the toner cartridge.
      หมายเหตุ
    Do not touch the imaging drum on the bottom of the tonercartridge. Fingerprints on the imaging drum can cause print qualityproblems.
    รูปภาพ : Do not touch the imaging drum
    Image: Do not touch the imaging drum
    รูปภาพ : Removing the toner cartridge from the packaging
    Image: Remove the toner cartridge from the packaging
  6. Grasp both ends of the toner cartridge, and then gently rock the toner cartridge back and forth to distribute the toner.
    รูปภาพ : Gently rocking the toner cartridge back and forth
    Image: Gently rock the toner cartridge back and forth
  7. Insert the new toner cartridge into the drawer. Make sure thatthe color chip on the cartridge matches the color chip on thedrawer.
    รูปภาพ : Inserting the toner cartridge into the printer
    Image: Insert the toner cartridge.
  8. Push the toner cartridge drawer into the printer.
    รูปภาพ : Pushing the toner cartridge drawer into the printer
    Image: Push in toner cartridge drawer
  9. Close the front door.
    รูปภาพ : Closing the toner cartridge drawer
    Image: Close the cartridge drawer
Review the list of frequently asked questions about replacing the toner cartridges.
ประเทศ/ภูมิภาค: Flag ไทย
