ฝ่ายสนับสนุนลูกค้า HP - ฐานความรู้
HP Deskjet Printers - Replacing the Ink Cartridges
This document is for HP Deskjet 1000, 2000, 3000, and Deskjet Ink Advantage 2010 printers.
To prevent print quality issues, replace the ink cartridges when they are low or out of ink.
Ink cartridges
HP Deskjet 1000, 2000, and 3000 printers
Consult the following table to identify the correct ink cartridges for your country/region.
Ink cartridge description
North America and Asia Pacific, including Japan (excluding India, China, and Indonesia)
Western Europe
Middle East, Africa, Latin America, and CIS
China, India, and Indonesia
Black ink cartridge
HP 61 Black
HP 301 Black
HP 122 Black
HP 802 Black
Color ink cartridge
HP 61 Tri-color
HP 301 Tri-color
HP 122 Tri-color
HP 802 Tri-color
HP Deskjet Ink Advantage 2010 printers
The Americas
Europe
Middle East and Africa
Asia Pacific
Black ink cartridge
HP 704 Black
N/A
N/A
HP 704 Black
Color ink cartridge
HP 704 Tri-Color
N/A
N/A
HP 704 Tri-Color
Video of replacing an ink cartridge
The following video demonstrates how to replace a cartridge.
บันทึก
The video shows the HP Deskjet 3000. The outside of the product might not look the same as your product, but the steps are the same.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Step one: Load paper
Whenever you install a new ink cartridge, the HP product prompts you to load paper so you can complete an ink cartridge alignment. Follow these steps to load paper in the product.
  1. If the product is not already on, press the Power button () to turn it on.
  2. Lift the paper tray.
    รูปภาพ : Lift the paper tray
    Illustration: Lifting the input tray
  3. Lower the output tray, and then pull the tray extender out.
    รูปภาพ : Lower the output tray
    Illustration: Lowering the output tray
  4. Slide the paper width guide to its outermost position.
    รูปภาพ : Slide the paper width guide
    Illustration: Sliding the paper width guide to its outermost position
  5. Load unused, plain white, U.S. letter or A4 size paper in the tray with the short edge forward and the print side up.
    รูปภาพ : Load paper in the tray
    Illustration: Loading paper in the tray
  6. Slide the paper width guide to the right until it stops at the edge of the paper but does not bend the paper.
    รูปภาพ : Slide the paper width guide to the right
    Illustration: Sliding the paper width guide to the right
Step two: Remove and replace the cartridge
  2. Open the ink cartridge door, and then wait for the carriage to move to the center of the product.
    รูปภาพ : Open the ink cartridge door
    Illustration: Opening the ink cartridge door
  3. Press down lightly on the ink cartridge that you want to replace to release it, and then pull it toward you out of its slot.
    รูปภาพ : Remove the old ink cartridge
    Illustration: Remove the old ink cartridge
  4. Remove the new ink cartridge from its package.
    รูปภาพ : Remove the ink cartridge from the package
    Illustration: Removing the new ink cartridge from the package
  5. Use the pink pull tab to remove the plastic protective tape from the new ink cartridge.
    รูปภาพ : Remove the plastic protective tape
    Illustration: Using the pull tab to remove the plastic protective tape
      หมายเหตุ
    Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Also, do not re-tape the cartridges. Doing so can result in clogs, ink failure, and bad electrical connections.
    รูปภาพ : Do not touch electrical contacts or ink nozzles
    Illustration: Areas not to touch
  6. Slide the new cartridge into its slot until it snaps firmly into place.
    รูปภาพ : Slide the cartridge into its slot
    Illustration: Sliding the cartridge into its slot
    • The tri-color ink cartridge () goes in the slot on the left
    • The black ink cartridge () goes in the slot on the right
  7. Repeat these steps to replace the other ink cartridge, if necessary.
  8. Close the ink cartridge door.
    รูปภาพ : Close the ink cartridge door
    Illustration: Closing the ink cartridge door
Step three: Align the new ink cartridge
  1. Open the printer software.
  2. Double-click Printer Actions, and then double-click Maintenance Tasks. The HP Toolbox opens.
  3. Click the Device Services tab, and then click Align Ink Cartridges. The printer aligns the cartridges and then prints an alignment page.
ประเทศ/ภูมิภาค: Flag ไทย
