- ${title}
กำลังโหลด...
ฝ่ายสนับสนุนลูกค้า HP - ฐานความรู้
- ${title}
กำลังโหลด...
- ${title}
กำลังโหลด...
- ${title}
กำลังโหลด...
HP LaserJet P1005, P1006, P1007, P1008, and P1009 Printers - Setting Up the LaserJet (Hardware)
Unpack the printer
Check the contents of the box
Install the print cartridge
Connect the power cord
Turn on power
Load plain paper
Setting up the printer
Follow these steps in order.
Step one: Unpack the printer
Remove all the orange shipping tape and packaging material from the product.
รูปภาพ : Unpack the printer
Step three: Install the print cartridge
Open the print cartridge door.รูปภาพ : Open the print cartridge door
Remove the new print cartridge from the packaging.
หมายเหตุ
To prevent damage to the print cartridge, hold the print cartridge at each end. -
Pull the tab to remove all the sealing tape from the print cartridge. Put the tab in the print cartridge box to return for recycling.รูปภาพ : Remove the sealing tape
Gently rock the print cartridge back and forth to distribute the toner evenly.รูปภาพ : Rock the print cartridge
Insert the print cartridge, and then close the print cartridge door.รูปภาพ : Insert the print cartridge
หมายเหตุ
If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
Step four: Connect the power cord
Connect the power cord to the rear of the product.รูปภาพ : Connect the power cord
Plug the power cord into an electrical outlet.
Step five: Turn on power
Press the Power button (
) to turn on the product.
Power button
รูปภาพ : Turn on the product
Step six: Load plain paper
To load plain paper in the main input tray, follow these steps.
Slide the paper length and width guides to their outermost positions.รูปภาพ : Slide out the paper guides
Load plain paper in the main input tray with the top forward and the print side up.
บันทึก
To prevent jams and skewing, always adjust the side and front paper guides. -
Slide the paper guides inward so that they rest against the stack of paper.รูปภาพ : Adjust the paper guides
ตัวเลือกการสนับสนุนเพิ่มเติม
- ${title}
กำลังโหลด...
- ${title}
กำลังโหลด...
- ${title}
กำลังโหลด...
ประเทศ/ภูมิภาค:
ไทย
- ${title}
กำลังโหลด...
hp-hero-support-search
- ${title}
กำลังโหลด...
