HP Color LaserJet Enterprise M652, M653 and HP Color LaserJet Enterprise MFP M681, M682 - Removal and replacement: Intermediate transfer belt (ITB)
This document provides the procedures to remove and replace the intermediate transfer belt.
Mean time to repair: 5 minutes
Service level: Basic
When applicable, special installation instructions are provided for an assembly at the end of the removal procedure. Always completely read the removal instructions and follow all special installation instructions.
Before performing service
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts
Intermediate transfer belt part numbers
P1B93-67901
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
Print a page and verify that the print quality is acceptable.
  1. Remove the intermediate transfer belt (ITB).
    1. Open the right door.
      Figure : Open the right door
    2. Release the blue latch (callout 1), and then lower the transfer assembly (callout 2).
      Figure : Lower the transfer assembly
    3. Grasp the two blue handles on the ITB.
      Figure : Grasp the two blue handles
    4. Pull the ITB partially out of the printer.
      Figure : Pull the ITB partially out of the printer
    5. Grasp the outside edges of the ITB to support it, and then remove the ITB from the printer.
      Figure : Remove the ITB
  2. Unpack the replacement assembly.
    1. Dispose of the defective part.
    2. Unpack the replacement part from the packaging.
      Some parts are sensitive to electrostatic discharge (ESD). Always perform service work at an ESD-protected workstation or mat. If an ESD workstation or mat is not available, touch the sheet-metal chassis to provide a static ground before touching an ESD-sensitive assembly. Protect the ESD-sensitive assemblies by placing them in ESD pouches when they are out of the printer.
      If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands before touching rollers or pads.
      Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
    3. To install an assembly, reverse the removal steps.
  3. Install the ITB.
    1. Remove the ITB from the packaging, and then remove the protective film around the ITB.
      Figure : Remove the protective film
    2. Handle the replacement ITB by the orange handles. Do not touch the grey-plastic belt. Skin oils and fingerprints on the belt can cause print-quality problems.
      Figure : Remove all packing materials
    3. Align the ITB with guides inside the printer, and then carefully push it into the printer until the orange handles stop it.
      Figure : Align the ITB
    4. Remove the orange handle. Repeat this step for the remaining orange handle.
      HP recommends recycling the plastic handles.
      Figure : Remove the orange handles
    5. Using the blue handles, continue to carefully push the ITB into the printer.
      Figure : Push the ITB into the printer
    6. Continue to push the ITB into the printer until you hear a click, confirming it is fully installed.
      Figure : Make sure the ITB clicks into place
    7. Close the right door.
      Figure : Close the right door
