HP Laptop 14s-er0503TU Product Specifications
49L36PA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2666 MHz RAM (1 x 8 GB)
Video graphics
Intel® UHD Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
14" diagonal, FHD (1920 x 1080), IPS, micro-edge, BrightView, 250 nits, 45% NTSC
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 USB 3.2 Gen 1 Type-C™ (5 Gb/s signaling rate, Data Transfer Only); 2 USB 3.2 Gen 1 Type-A (5 Gb/s signaling rate, Data Transfer Only); 1 HDMI 1.4b; 1 AC smart pin; 1 headphone/microphone combo
32.4 x 22.59 x 1.99 cm
Starting at 1.49 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP True Vision 720p HD camera with integrated digital microphone
Audio
Dual speakers
Windows 10 Home
