HP Laptop 15s-gu0014AU Product Specifications
265A1PA
AMD Athlon™ Silver 3050U (2.3 GHz base clock, up to 3.2 GHz max boost clock, 4 MB L3 cache, 2 cores, 2 threads)
AMD Integrated SoC
4 GB DDR4-2400 MHz RAM (1 x 4 GB)
Video graphics
AMD Radeon™ Graphics
1 TB 5400 rpm SATA HDD
15.6" diagonal, HD (1366 x 768), micro-edge, BrightView, 220 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.74 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Audio
Dual speakers
Windows 11 Home
