HP All-in-One 24-cb0136m All-in-One PC Product Specifications
Product Number
20W73AA
Product Name
23.8" diagonal FHD display
Display Specifications
23.8" diagonal, FHD (1920 x 1080), IPS, three-sided micro-edge, anti-glare, 250 nits, 72% NTSC
Motherboard
Mercedes
Motherboard Specifications Link
Memory
8 GB DDR4-3200 MHz RAM (2 x 4 GB)
Memory & Storage
8 GB memory; 512 GB SSD storage
Internal Storage
512 GB PCIe® NVMe™ M.2 SSD
Processor Type
AMD Ryzen 3
Processor
AMD Ryzen™ 3 5300U (up to 3.8 GHz max boost clock, 4 MB L3 cache, 4 cores, 8 thread)
Processor Family
AMD Ryzen™ 3 processor
Graphics
Integrated
Graphics Card
AMD Radeon™ Graphics
Ports
1 SuperSpeed USB Type-A 5Gbps signaling rate (Battery Charging 1.2); 2 USB 2.0 Type-A; 1 RJ-45
Expansion Slots
2 M.2 (1 for SSD, 1 for WLAN)
Network Interface
Wireless
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
Dimensions
54.06 x 18.37 x 41.9 cm
5.37 kg
Power Supply Type
90 W Smart AC power adapter
Keyboard
HP 310 Black Wired Keyboard and mouse combo
HP Wide Vision 1080p FHD IR privacy camera with integrated dual array digital microphones
HP Apps
HP Audio Stream; HP Connection Optimizer; HP Games by WildTangent; HP Support Assistant; HP QuickDrop; HP BIOS Protection; OMEN Gaming Hub; HP Enhanced Lighting
Software Included
Operating System
Windows 11 Home
