Victus by HP Laptop 16-e0002nh Product Specifications
4P842EA
AMD Ryzen™ 5 5600H (up to 4.2 GHz max boost clock, 16 MB L3 cache, 6 cores, 12 threads)
AMD Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce RTX™ 3050 Ti Laptop GPU (4 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
40.9 cm (16.1") diagonal, FHD (1920 x 1080), 144 Hz, 7 ms response time, IPS, micro-edge, anti-glare, Low Blue Light, 300 nits, 100% sRGB
Realtek Wi-Fi 6 (2x2) and Bluetooth® 5.2 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 5Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.1; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
37 x 26 x 2.35 cm
2.46 kg
200 W Smart AC power adapter
4-cell, 70 Wh Li-ion polymer
Battery life mixed usage
Up to 8 hours and 45 minutes
Video Playback Battery life
Up to 11 hours and 30 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by B&O; Dual speakers; HP Audio Boost
Windows 10 Home
HP Audio Switch; HP Connection Optimizer; HP CoolSense; HP QuickDrop; OMEN Gaming Hub
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
