OMEN Laptop 15-en1039nl Product Specifications
46B05EA
AMD Ryzen™ 7 5800H (up to 4.4 GHz max boost clock, 16 MB L3 cache, 8 cores, 16 threads)
AMD Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce RTX™ 3060 Laptop GPU (6 GB GDDR6 dedicated)
1 TB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), 144 Hz, 7 ms response time, IPS, micro-edge, anti-glare, 300 nits, 72% NTSC
Intel® Wi-Fi 6 AX200 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 5Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.1; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.79 x 23.97 x 2.29 cm
2.46 kg
200 W Smart AC power adapter
6-cell, 70.9 Wh Li-ion polymer
Battery life mixed usage
Up to 8 hours
Video Playback Battery life
Up to 9 hours
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; DTS:X® Ultra; Dual speakers; HP Audio Boost
HP Audio Switch; HP Connection Optimizer; HP QuickDrop; OMEN Gaming Hub
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
