Product Specifications for the HP Smart Tank 725 All-in-One (28B51A)
Product naming
Model name
28B51A
What's included and accessories
What's in the box
HP Smart Tank 725 All-in-One; 3 x HP GT53XL 135-ml Black Original Ink Bottle; HP GT52 Cyan Original Ink Bottle; HP GT52 Magenta Original Ink Bottle; HP GT52 Yellow Original Ink Bottle; Power cord; HP Black color printhead; HP Tri color printhead; Setup guide; Reference guide; Ink caution flyer; Regulatory flyers; warranty flyers; For more information about fill and yield, see http://www.hp.com/go/learnaboutsupplies
Connectivity
Ports
Hi-Speed USB 2.0; Wi-Fi; Bluetooth LE
Wireless capability
Yes, 2.4/5G dual band Wi-Fi, Wi-Fi Direct, BLE
Copy
Copier settings
Number of Copies, Resize, Quality, Lighter/Darker, Papersize, Papertype, ID Copy
Color copy capability
Yes
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy resolution
Up to 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.5 B(A) (printing at 10ppm)
Acoustic pressure emissions
59.4 dB(A) (printing at 10ppm)
Recommended operating humidity range
20 to 80% RH
Non-Operating Humidity Range
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30°C
Recommended operating temperature range (Fahrenheit)
59 to 86°F
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140°F
Environmental specifications
25% post-consumer recycled plastic; Recyclable through HP Planet Partners
Memory
Memory
128 MB
Maximum Memory
128 MB
Mobile printing capability
Mobile printing services
Apple AirPrint; Mopria Print Service; HP Print Service Plugin (Android printing); HP Smart app; Wi-Fi Direct Printing
Paper handling
Input capacity
Up to 250 sheets
Standard input capacity (cards)
Up to 30 cards
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A6; B5 (JIS); Envelope (DL, C5, C6, Chou #3, Chou #4); Card (Hagaki, Ofuku Hagaki)
Media sizes supported (U.S. standard)
Letter; Legal; Government Legal; Executive; Statement; 4 x 6 in; 5 x 7 in; 8 x 10 in; L; Photo 2L; Envelope( #10, Monarch, 5.5 bar); Card (4 x 6 in, 5 x 8 in)
Media sizes, custom (metric)
88.9 x 127 mm to 215.9 x 355.6 mm
Media sizes, custom (U.S. standard)
3.5 x 5 in to 8.5 x 14 in
Media types
Plain Paper, HP Photo Papers, HP Matte Brochure or Professional Paper, HP Matte Presentation Paper, HP Glossy Brochure or Professional Paper, Other Photo Inkjet Papers, Other Matte Inkjet Papers, Other Glossy Inkjet Papers, Light/Recycled
Media weight supported (metric)
Plain paper: 60 to 105 g/m²; Envelopes: 75 to 90 g/m²; Cards: up to 200 g/m²; Photo paper: up to 250 g/m²
Media weight supported (U.S. standard)
16 to 28 lb
Borderless printing
Yes (up to 8.5 x 11 in, 210 x 297 mm)
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Letter; Executive; Not Supported for Borderless
Physical dimensions
Maximum dimensions (W x D x H, metric)
427.54 x 440.73 x 198.55 mm
Maximum dimensions (W x D x H, U.S. standard)
16.83 x 17.35 x 7.82 in
Weight (metric)
6.38 kg
Weight (U.S. standard)
14.07 lb
Power
Internal
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
Power consumption
0.10 Watts (Off Mode), 2.00 Watts ( Sleep mode)
Print cartridges
Replacement cartridges
HP GT53 90-ml Black bottle (~4000 pages); HP 53XL 135-ml Black bottle (~6000 pages); HP GT52 70-ml Cyan bottle (~8000 pages); HP GT52 70-ml Magenta bottle (~8000 pages); HP GT52 70-ml Yellow bottle (~8000 pages). For more information about fill and yield see www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic
Print speed black (ISO)
Up to 15 ppm
Print speed color (ISO)
Up to 9 ppm
Print resolution (best)
Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200 input dpi
Maximum print area (metric)
215.9 x 355.6 mm
Monthly duty cycle
Up to 5,000 pages
Print languages
HP PCL 3 GUI
Printer smart software features
Duplex printing
Regulatory specifications
Ecolabels
EPEAT® registered; CECP
Safety
IEC 60950-1 & IEC 62368-1 Ed. 2 compliant; Safety CSA NRTL; EU RED and EN 62368-1 Ed. 2 compliant; NEMKO GS approved; Mexico NOM-1-NYCE, Singapore "Safety Mark"; Russia EAC; China CCC
Electromagnetic compatibility
CISPR 32:2015/EN 55032:2015+A11:2020 Class B; CISPR24:2010+A1:2015/EN 55024:2010+A1:2015; EN55035:2017+A11:2020/CISPR35:2016; EN 61000-3-2:2019; EN 61000-3-3:2013+A1:2019; FCC CFR 47 Part 15 Subpart B; ICES-003 Issue 7:2020; EN 301 489-1 V2.2.3; EN 301 489-17 V3.2.2
Telecom compliance (fax capability)
EN 300 328 V2.2.2; EN 301 893 V2.1.1; EN 300 440 V2.1.1
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, 7: 32-bit or 64-bit, 2 GB available hard disk space, Internet connection, Internet Explorer.
Recommended system requirements for Windows
Windows 10, Windows 7 Service Pack 1 (SP1): 32-bit or 64-bit, 2 GB available hard disk space, Internet connection, Internet Explorer.
Minimum System Requirements for Macintosh
macOS v10.14 Mojave, macOS v10.15 Catalina, macOS v11 Big Sur; 2 GB HD; Internet required
Recommended Macintosh system requirements
Operating system (supported note)
Windows10, Windows 7 Service Pack 1 (SP1): 32-bit or 64-bit; macOS v10.14 Mojave, macOS v10.15 Catalina, macOS v11 Big Sur; 2 GB available hard disk space, Internet connection, Internet Explorer.
Manufacturer Warranty
Up to 3 years extended warranty upon registration at http://www.hp.com/go/SmartTank3yearswarranty. User replaceable parts have separate warranty periods.
