    Find Windows 11 and Windows 10 support help. Click here
HP ENVY x360 Convert 15-eu0032ur Product Specifications
4E1R0EA
AMD Ryzen™ 7 5700U (up to 4.3 GHz max boost clock, 8 MB L3 cache, 8 cores, 16 threads)
AMD Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
AMD Radeon™ Graphics
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB
Realtek Wi-Fi CERTIFIED 6™ (2x2) and Bluetooth® 5.2 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate; 1 HDMI 2.0b; 1 AC smart pin; 1 headphone/microphone combo
35.9 x 22.82 x 1.84 cm
2.07 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 14 hours and 15 minutes
Video Playback Battery life
Up to 12 hours and 30 minutes
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost
HP Audio Switch; HP Connection Optimizer; HP Command Center; HP QuickDrop; OMEN Gaming Hub; HP Display Control
