HP Chromebook 14b-na0001sl Product Specifications
3Y6H7EA
AMD Athlon™ Silver 3050C (up to 3.2 GHz max boost clock, 4 MB L3 cache, 2 cores, 2 threads)
AMD Integrated SoC
4 GB DDR4-2400 MHz RAM (onboard)
Video graphics
AMD Radeon™ Graphics
64 GB eMMC
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Intel® Wi-Fi CERTIFIED 6™ AX200 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader
2 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2); 2 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 HDMI 1.4; 1 headphone/microphone combo
32.36 x 22.1 x 1.65 cm
1.51 kg
45 W USB Type-C® power adapter
3-cell, 58 Wh Li-ion polymer
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by B&O; Dual speakers
Chrome OS™
