HP Chromebook x360 14a-cb0010ng Product Specifications
4C259EA
AMD 3015Ce (up to 2.3 GHz max boost clock, 4 MB L3 cache, 2 cores, 4 threads)
AMD Integrated SoC
4 GB DDR4-3200 MHz RAM (onboard)
Video graphics
AMD Radeon™ Graphics
64 GB eMMC
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), touch, IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
2 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 headphone/microphone combo
32.55 x 21.96 x 1.82 cm
1.47 kg
45 W USB Type-C® power adapter
2-cell, 47 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours and 30 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Dual speakers
Chrome OS™
