    Find Windows 11 and Windows 10 support help. Click here
HP Laptop 15s-gr0504AU Product Specifications
4B6D4PA
AMD Ryzen™ 3 3300U (2.1 GHz base clock, up to 3.5 GHz max boost clock, 4 MB L3 cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2400 MHz RAM (1 x 8 GB)
Video graphics
AMD Radeon™ Graphics
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 5400 rpm SATA HDD
Optical drive
Optical drive not included
15.6" diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.74 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 5 hours
Dual speakers
