    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Product Specifications for the HP Laser 108a (4ZB79A)
Product naming
Model name
HP Laser 108a
4ZB79A
What's included and accessories
What's in the box
Preinstalled introductory HP Laser Black print cartridges (~1.5K pages, CH/IN); Setup Guide; Reference Guide; Regulatory Statements Flyer; Power cord; USB cable
Connectivity
Ports
Hi-Speed USB 2.0 port
Environmental
Acoustic power emissions (active, printing)
6.5 B(A)
Recommended operating humidity range
20 to 70% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 27°C
Recommended operating temperature range (Fahrenheit)
59 to 80.6°F
Storage temperature range (Celsius)
-20 to 40°C
Storage temperature range (Fahrenheit)
-4 to 104°F
Environmental specifications
Mercury free
Memory
Memory
64 MB
Maximum Memory
64 MB
Memory card compatibility
None
Mobile printing capability
Mobile printing services
HP Smart App; Apple AirPrint™; Google Cloud Print™; Mobile Apps; Mopria™-certified
Paper handling
Input capacity
Up to 150 sheets
Standard input capacity (envelopes)
Up to 10
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A5(LEF); B5 (JIS); Oficio; Envelope (DL, C5); 76 x 127 to 216 x 356mm
Media sizes supported (U.S. standard)
Letter; Legal; Executive; Oficio 216x340mm, Oficio 8.5x13 in, Envelope (No.10, Monarch); 4x6 in
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Plain, Thick, Thin, Cotton, Color, Preprinted, Recycled, Labels, CardStock, Bond, Archive, Envelope
Media weight supported (metric)
60 to 163 g/m²
Media weight supported (U.S. standard)
16 to 43 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
331 x 350 x 248 mm
Maximum dimensions (W x D x H, U.S. standard)
13.03 x 13.78 x 9.76 in
Weight (metric)
4.18 kg
Weight (U.S. standard)
9.22 lb
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology; Power save
Internal (built-in) Power Supply
Power supply
110-volt input voltage: 110 to 127 VAC, 50/60Hz and 220-volt input voltage: 220 to 240 VAC, 50/60Hz. Not dual voltage, power supply varies by part number with # Option code identifier.
Power consumption
320 watts (Active Printing), 33 watts (Ready), 1.1 watts (Sleep), 0.2 watts (Manual off), 0.2 watts (Auto off/Manual on)
Print cartridges
Number of print cartridges
1 (black)
Replacement cartridges
HP 110A Black Original Laser Toner Cartridge (~1500 yield) W1110A; HP 110A Black Original Laser Toner Cartridge (~1500 yield) W1112A
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 1,200 x 1,200 dpi
Maximum print area (metric)
216 x 356 mm
Monthly duty cycle
Up to 10,000 pages
Print languages
SPL
Printer smart software features
Manual duplex, N-up printing, collation, watermarks, accepts a variety of paper sizes and types
Regulatory specifications
Regulatory model number
SEOLA-1802-00
Ecolabels
CECP
Safety
GB4943.1-2011; IS 13252(PART 1): 2010
Electromagnetic compatibility
GB17625.1-2012
System requirements
Minimum system requirements for Windows
Windows 7 or newer, Intel® Pentium® IV 1 GHz 32-bit or 64-bit processor or higher, 1 GB RAM, 16 GB HDD
Compatible Network Operating Systems
Windows®: 7 (32/64 bit), 2008 Server R2, 8 (32/64 bit), 8.1 (32/64 bit), 10 (32/64 bit), 2012 Server, 2016 Server
Operating system (supported note)
Windows 7 or higher
Manufacturer Warranty
One-year limited hardware warranty; For more info please visit us at https://support.hp.com
