    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Product Specifications for the HP DeskJet 2742e All-in-One Printer (26K71A)
Product naming
Model name
26K71A
What's included and accessories
What's in the box
HP DeskJet 2742e All-in-One Printer; HP 67 Setup Black Cartridge; HP 67 Setup Tri-Color Cartridge; Regulatory flyer; Setup guide; Reference guide; Power cord [For ink volume and page yield information, visit http://hp.com/go/learnaboutsupplies
Accessories
None
Connectivity
Ports
1 Wireless 802.11a/b/g/n; 1 Hi-Speed USB 2.0
Wireless capability
Yes
Storage device and direct print support
Storage devices not supported
Copy
Copier settings
Auto-enlarge
Color copy capability
Yes
Maximum number of copies
Up to 6 copies
Copy reduce / enlarge settings
Via HP Smart app
Environmental
Acoustic power emissions (active, printing)
6.2 B(A)
Acoustic pressure emissions
48 dB(A)
Recommended operating humidity range
20 to 80% RH (non-condensing)
Non-Operating Humidity Range
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30°C
Recommended operating temperature range (Fahrenheit)
59 to 86°F
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140°F
Environmental specifications
None
Fax
Fax available
Yes, mobile fax (send only)
Modem
None
Memory
Memory
64 MB DDR1; 20 MB Flash
Maximum Memory
Mobile printing capability
Mobile printing services
HP Smart app; Apple AirPrint™; Chrome OS; Mopria-certified
Paper handling
Input capacity
Up to 60 sheets
Standard input capacity (cards)
Up to 20 cards
Standard input capacity (envelopes)
Up to 5
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; B5; A6; DL envelope
Media sizes supported (U.S. standard)
Letter; legal; 4 x 6 in; 5 x 7 in; 8 x 10 in; No. 10 envelopes
Media sizes, custom (metric)
89 x 127 to 215 x 279 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Plain paper, photo paper, brochure paper, envelopes and other specialty inkjet papers
Media weight supported (metric)
75 g/m²
Media weight supported (U.S. standard)
Letter: 16 to 32 lb; HP envelopes: 20 to 24 lb; HP cards: up to 110 lb; HP 4 x 6 inch photo paper: up to 145 lb
Borderless printing
No
Paper handling - ADF
Automatic document feeder capacity
No
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Not Applicable
Physical dimensions
Maximum dimensions (W x D x H, metric)
425 x 546 x 250 mm (Output Extension fully out)
Maximum dimensions (W x D x H, U.S. standard)
16.7 x 21.5 x 9.8 inch (Output Extension fully out)
Weight (metric)
3.42 kg
Weight (U.S. standard)
7.55 lb
Power
Internal
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
Power consumption
2.5 Watts (Ready) ; 1.1 Watts (Sleep); 0.15 Watts (Off) ; 0.15 Watts (Auto-off)
Print cartridges
Number of print cartridges
2 (1 each black, tri-color)
Replacement cartridges
HP 67 Black Original Ink Cartridge (~120 pages yield) 3YM56AN; HP 67XL Black High Yield Original Ink Cartridge (~240 pages yield) 3YM57AN; HP 67XXL Black Extra High-Yield Original Ink Cartridge (~400 pages yield) 3YM59AN; HP 67 Tri-Color Original Ink Cartridge (~100 pages yield) 3YM55AN; HP 67XL Tri-Color High-Yield Original Ink Cartridge (~200 pages yield) 3YM58AN; HP 67XXL Tri-Color Extra High-Yield Original Ink Cartridge (~330 pages yield) 6ZA16AN: Actual yield varies considerably based on content of printed pages and other factors. For details see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Manual (driver support provided)
Print speed black (ISO)
Up to 7 ppm
Print speed color (ISO)
Up to 5 ppm
Print resolution (best)
Up to 4800 x 1200 optimized dpi color (when printing from a computer on selected HP photo papers and 1200 input dpi)
Maximum print area (metric)
215 x 355 mm
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI; HP PCLm (HP Apps/UPD); URF (AirPrint)
Regulatory specifications
Regulatory model number
SNPRC-1901-01
Safety
IEC 60950-1:2005 +A1:2009 +A2:2013, EN 60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013, IEC 62368-1:2014, EN 62368-1:2014 +A11:2017, EN 62479:2010, EN 62311:2008
Electromagnetic compatibility
EN 55032:2015 / CISPR 32:2015 Class B, EN 55024:2010 / CISPR 24:2010, EN 55035:2017 / CISPR 35:2016, EN 61000-3-2:2014 / IEC 61000-3-2:2014, EN 61000-3-3:2013 / IEC 61000-3-3:2013, FCC CFR 47 Part 15 Class B, ICES-003, Issue 6 Class B, EN 301 489-1 V2.1.1:2017, EN 301 489-17 V3.1.1:2017
Telecom compliance (fax capability)
EN 300 328 V2.1.1:2016; EN 301 893 V2.2.1:2017
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Scanning options (ADF)
Not Applicable
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, Windows 7 Service Pack 1 (SP1): 32-bit or 64-bit, 2 GB available hard disk space, Internet connection, Internet Explorer.
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
macOS v10.14 Mojave, macOS v10.15 Catalina, macOS v11 Big Sur; 2 GB HD; Internet required
Recommended Macintosh system requirements
Compatible Network Operating Systems
Windows 10, Windows 7 Service Pack 1 (SP1); MacOS Sierra v10.12 (previously OS X), macOS High Sierra v10.13, macOS Mojave v10.14, macOS Catalina v10.15, Chrome OS
Manufacturer Warranty
One-year limited hardware warranty; 24-hour, 7 days a week support
