    Find Windows 11 and Windows 10 support help. Click here
Product Specifications for the HP DeskJet 2742e All-in-One Printer (26K70A)
Product naming
Model name
26K70A
What's included and accessories
What's in the box
HP DeskJet 2742e All-in-One Printer; HP 67 Setup Black Cartridge; HP 67 Setup Tri-Color Cartridge; Regulatory flyer; Setup guide; Reference guide; Power cord [For ink volume and page yield information, visit http://hp.com/go/learnaboutsupplies]
Accessories
None
Connectivity
Ports
1 Wireless 802.11a/b/g/n; 1 Hi-Speed USB 2.0
Wireless capability
Yes
Storage device and direct print support
Storage devices not supported
Copy
Copier settings
Auto-enlarge
Color copy capability
Yes
Maximum number of copies
Up to 6 copies
Copy reduce / enlarge settings
Via HP Smart app
Environmental
Acoustic power emissions (active, printing)
6.2 B(A)
Acoustic pressure emissions
48 dB(A)
Recommended operating humidity range
20 to 80% RH (non-condensing)
Non-Operating Humidity Range
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30°C
Recommended operating temperature range (Fahrenheit)
59 to 86°F
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140°F
Environmental specifications
None
Fax
Fax available
Yes, mobile fax (send only)
Modem
None
Memory
Memory
64 MB DDR1; 20 MB Flash
Maximum Memory
Mobile printing capability
Mobile printing services
HP Smart app; Apple AirPrint™; Chrome OS; Mopria-certified
Paper handling
Input capacity
Up to 60 sheets
Standard input capacity (cards)
Up to 20 cards
Standard input capacity (envelopes)
Up to 5
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; B5; A6; DL envelope
Media sizes supported (U.S. standard)
Letter; legal; 4 x 6 in; 5 x 7 in; 8 x 10 in; No. 10 envelopes
Media sizes, custom (metric)
89 x 127 to 215 x 279 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Plain paper, photo paper, brochure paper, envelopes and other specialty inkjet papers
Media weight supported (metric)
75 g/m²
Media weight supported (U.S. standard)
Letter: 16 to 32 lb; HP envelopes: 20 to 24 lb; HP cards: up to 110 lb; HP 4 x 6 inch photo paper: up to 145 lb
Borderless printing
No
Paper handling - ADF
Automatic document feeder capacity
No
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Not Applicable
Physical dimensions
Maximum dimensions (W x D x H, metric)
425 x 546 x 250 mm (Output Extension fully out)
Maximum dimensions (W x D x H, U.S. standard)
16.7 x 21.5 x 9.8 inch (Output Extension fully out)
Weight (metric)
3.42 kg
Weight (U.S. standard)
7.55 lb
Power
Internal
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
Power consumption
2.5 Watts (Ready) ; 1.1 Watts (Sleep); 0.15 Watts (Off) ; 0.15 Watts (Auto-off)
Print cartridges
Number of print cartridges
2 (1 each black, tri-color)
Replacement cartridges
HP 67 Black Original Ink Cartridge (~120 pages yield) 3YM56AN; HP 67XL Black High Yield Original Ink Cartridge (~240 pages yield) 3YM57AN; HP 67XXL Black Extra High-Yield Original Ink Cartridge (~400 pages yield) 3YM59AN; HP 67 Tri-Color Original Ink Cartridge (~100 pages yield) 3YM55AN; HP 67XL Tri-Color High-Yield Original Ink Cartridge (~200 pages yield) 3YM58AN; HP 67XXL Tri-Color Extra High-Yield Original Ink Cartridge (~330 pages yield) 6ZA16AN: For details see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Manual (driver support provided)
Print speed black (ISO)
Up to 7 ppm
Print speed color (ISO)
Up to 5 ppm
Print resolution (best)
Up to 4800 x 1200 optimized dpi color (when printing from a computer on selected HP photo papers and 1200 input dpi)
Maximum print area (metric)
215 x 355 mm
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI; HP PCLm (HP Apps/UPD); URF (AirPrint)
Regulatory specifications
Regulatory model number
SNPRC-1901-01
Safety
IEC 60950-1:2005 +A1:2009 +A2:2013, EN 60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013, IEC 62368-1:2014, EN 62368-1:2014 +A11:2017, EN 62479:2010, EN 62311:2008
Electromagnetic compatibility
EN 55032:2015 / CISPR 32:2015 Class B, EN 55024:2010 / CISPR 24:2010, EN 55035:2017 / CISPR 35:2016, EN 61000-3-2:2014 / IEC 61000-3-2:2014, EN 61000-3-3:2013 / IEC 61000-3-3:2013, FCC CFR 47 Part 15 Class B, ICES-003, Issue 6 Class B, EN 301 489-1 V2.1.1:2017, EN 301 489-17 V3.1.1:2017
Telecom compliance (fax capability)
EN 300 328 V2.1.1:2016; EN 301 893 V2.2.1:2017
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Scanning options (ADF)
Not Applicable
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, Windows 7 Service Pack 1 (SP1): 32-bit or 64-bit, 2 GB available hard disk space, Internet connection, Internet Explorer.
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
macOS v10.14 Mojave, macOS v10.15 Catalina, macOS v11 Big Sur; 2 GB HD; Internet required
Recommended Macintosh system requirements
Compatible Network Operating Systems
Windows 10, Windows 7 Service Pack 1 (SP1); MacOS Sierra v10.12 (previously OS X), macOS High Sierra v10.13, macOS Mojave v10.14, macOS Catalina v10.15, Chrome OS
Manufacturer Warranty
One-year limited hardware warranty; 24-hour, 7 days a week support
