Product Specifications for the HP OfficeJet 8014 All-in-One Printer (3UC57B)
Product naming
Model name
3UC57B
What's included and accessories
What's in the box
HP OfficeJet 8014 All-in-One Printer; HP 912 Setup Black Ink Cartridge; HP 912 Setup Cyan Ink Cartridge; HP 912 Setup Magenta Ink Cartridge; HP 912 Setup Yellow Ink Cartridge; User guide; Setup poster; Power cord; For ink volume and page yield information, please visit http://www.hp.com/go/learnaboutsupplies
Connectivity
Ports
1 Wireless 802.11a/b/g/n
Wireless capability
Yes, built-in Wi-Fi 802.11a/b/g/n
Copy
Copier settings
Number of Copies; Two-Sided; Lighter/Darker; ID Copy; Resize; Quality; Paper Size; Paper Type; Collate; Margin Shift; Crop; Copy Preview; Enhancements
Color copy capability
Yes
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed, black (draft, A4)
Up to 28 cpm
Copy resolution
Up to 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.5 B(A) (printing at 15 ppm)
Acoustic pressure emissions
61 dB(A) (printing at 17 ppm)
Recommended operating humidity range
20 to 80% RH
Recommended operating temperature range (Celsius)
15 to 32°C
Storage temperature range (Celsius)
-40 to 60°C
Memory
Memory
256 MB
Maximum Memory
256 MB DDR3 SDRAM
Mobile printing capability
Mobile printing services
Chrome OS; HP Smart app; Apple AirPrint™; Wi-Fi® Direct Printing; Mopria™ Certified
Networking
Network protocols, supported
9100; LPR; SNMP; SLP; Internet Printing Protocol (IPP); WS-Print; Wireless
Paper handling
Input capacity
Up to 225 sheets
Standard input capacity (cards)
Up to 60 sheets
Standard input capacity (envelopes)
Up to 10 envelopes
Output capacity
Up to 60 sheets
Media sizes supported (metric)
A4, A5, A6, B5(JIS); Card A4; Photo (13 x 18 cm, 10 x 15 cm); Envelope (A2, C5, C6, DL)
Media sizes, custom (metric)
Tray 1: 76.2 x 127 to 215.9 x 355.6 mm
Media types
Plain Paper, HP Photo Papers, HP Matte Brochure or Professional Paper, HP Matte Presentation Paper, HP Glossy Brochure or Professional Paper, other Photo Inkjet Papers, other Matte Inkjet Papers, other Glossy Inkjet Papers, Thick Plain Paper, Light/Recycled Plain Paper, HP Tri-fold Brochure Paper, Glossy
Media weight supported (metric)
60 to 105 g/m² (plain); 220 to 280 g/m² (photo); 75 to 90 g/m² (envelope); 163 to 200 g/m² (card)
Borderless printing
Yes, on photo paper only (up to 210 x 279 mm)
Paper handling - ADF
Automatic document feeder capacity
Standard, 35 sheets
Physical dimensions
Maximum dimensions (W x D x H, metric)
460 x 511.25 x 233 mm
Weight (metric)
8.2 kg
Power
Energy savings feature technology
Schedule On and Schedule Off
Internal (Built-in) Universal Power Supply
Power supply
Input voltage: 220 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
Power consumption
Up to 21 watts (Printing), 5.80 watts (Ready), 0.90 watts (Sleep), 0.08 watts (Manual-Off)
Print cartridges
Number of print cartridges
4 (1 each black, cyan, magenta, yellow)
Replacement cartridges
HP 912 Black Original Ink Cartridge (~300 pages) 3YL80A; HP 912 Cyan Original Ink Cartridge (~315 pages) 3YL77A; HP 912 Magenta Original Ink Cartridge (~315 pages) 3YL78A; HP 912 Yellow Original Ink Cartridge 3YL79A (~315 pages); HP 912XL Black Original Ink Cartridge (~825 pages) 3YL84A; HP 912XL Cyan Original Ink Cartridge (~825 pages) 3YL81A; HP 912XL Magenta Original Ink Cartridge (~825 pages) 3YL82A; HP 912XL Yellow Original Ink Cartridge 3YL83A (~825 pages); Actual yield varies considerably based on content of printed pages and other factors, for details see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic (standard)
Print speed black (ISO)
Up to 18 ppm
Print speed color (ISO)
Up to 10 ppm
Print resolution (best)
1200 x 1200 rendered dpi
Maximum print area (metric)
210 x 297 mm
Monthly duty cycle
Up to 20,000 pages
Print languages
HP PCL3 GUI
Printer smart software features
Orientation: Portrait/Landscape; Print on Both Sides: None/Flip on Long Edge/Flip on Short Edge; Page Order: Front to Back/Back to Front; Pages per Sheet: 1, 2, 4, 6, 9, 16; Quality Settings: Draft/Normal/Best; Printing Shortcuts; Print in Greyscale: Off/High Quality Greyscale/Black Ink Only; Pages per Sheet Layout: Right then Down/Down then Right/Left then Down/Down then Left; Print in Max DPI: No/Yes; HP Real Life Technologies: Off/On; Booklet: None/Booklet-Left Binding/Booklet-Right Binding; Pages to Print: Print All Pages/Print Odd Pages Only/Print Even Pages Only; Borderless Printing: Off/On; Page Borders: Off/On
Regulatory specifications
Safety
IEC 60950-1:2005 (2nd Edition) Am1:2009+Am2:2013/EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013; IEC62368-1:2014 (2nd Edition)/EN62368-1:2014+A11:2017; UL 62368-1: 2nd Edition; German GS; Russia EAC
Electromagnetic compatibility
CISPR 32:2012/EN 55032:2012 Class B; CISPR 24:2010/EN 55024:2010; EN 61000-3-2:2014; EN 61000-3-3:2013; EN 301 489-1 (V2.1.1:2017); EN 301 489-17 (V3.1.1 2017)
Telecom compliance (fax capability)
ES 203 021-2, ES 203 021-3; Radio Equipment Directive 2014/53/EU
Scan
Scan technology
Contact Image Sensor (CIS)
Scan speed (normal)
Up to 8 ppm (200 ppi, black and white), up to 3.5 ppm (200 ppi, colour)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
215.9 x 297 mm
Minimum ADF scan size (metric)
127 x 127 mm
Maximum ADF scan size (metric)
215.9 x 355.6 mm
Twain version
Version 2.1
Security
Security management
SSL/TLS (HTTPS); IPP over TLS; WPA2-Enterprise; WPA2-Personal; Certificates configuration; Control panel lock; Password protect EWS; Unused protocol and service disablement; Signed firmware; Administrator settings
System requirements
Minimum system requirements for Windows
Windows 10, 8.1, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
OS X v10.11 El Capitan; macOS Sierra v10.12 (previously OS X); macOS High Sierra v10.13; macOS Mojave v10.14; 1.5 GB available hard disk space; Internet access
Recommended Macintosh system requirements
Compatible Network Operating Systems
Windows 10, 8.1, 8, 7, OS X v10.11 El Capitan, macOS Sierra v10.12 (previously OS X); macOS High Sierra v10.13, Linux, Chrome OS
Operating system (supported note)
Windows XP and Windows Vista not supported
Manufacturer Warranty
One-year limited hardware warranty; Possibility to get 3 years warranty upon customer registration, under T&Cs http://www.hp.com/eu/warrantyextension; 24-hour, 7 days a week Web support; Business hour phone support within warranty period
