HP Chromebook x360 14b-cb0811nd Product Specifications
402K6EA
Intel® Pentium® Silver N6000 (up to 3.3 GHz burst frequency, 4 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB LPDDR4x-2933 MHz RAM (onboard)
Video graphics
Intel® UHD Graphics
128 GB eMMC
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, 250 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 microSD media card reader
2 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 headphone/microphone combo
32.63 x 21.96 x 1.85 cm
1.62 kg
45 W USB Type-C® power adapter
2-cell, 47 Wh Li-ion polymer
Battery life mixed usage
Up to 11 hours and 15 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by B&O; Dual speakers
Chrome OS™
