    Windows 11 Upgrade Guide
HP Laptop 15s-du3024TU Product Specifications
2W2Y1PA
Intel® Core™ i5-1135G7 (up to 4.2 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2666 MHz RAM (2 x 4 GB)
Video graphics
Intel® Iris® Xᵉ Graphics
1 TB 5400 rpm SATA HDD
Optical drive
Optical drive not included
15.6" diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.75 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 5 hours and 15 minutes
Video Playback Battery life
Up to 7 hours and 15 minutes
Dual speakers
HP Audio Switch; HP Support Assistant; HP Connection Optimizer; HP BIOS Recovery; HP QuickDrop
McAfee LiveSafe™ 30-day trial offer (Internet access required. First 30 days included. Subscription required for live updates afterwards.)
