    Windows 11 Upgrade Guide
HP Laptop 15s-eq1249nb Product Specifications
2U3L1EA
AMD Ryzen™ 3 4300U (2.7 GHz base clock, up to 3.7 GHz max boost clock, 4 MB L3 cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2666 SDRAM (2 x 4 GB)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 15 minutes
Video Playback Battery life
Up to 9 hours
Dual speakers
Pre-installed software
Netflix; ExpressVPN (30 day free trial)
