HP Laptop 15s-eq1138AU Product Specifications
20U83PA
AMD Ryzen™ 5 4500U (2.3 GHz base clock, up to 4.0 GHz max boost clock, 8 MB L3 cache, 6 cores)
AMD Integrated SoC
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
Keyboard
Full-size, backlit, natural silver keyboard with numeric keypad
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
35.85 x 24.2 x 1.79 cm
Starting at 1.7 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 15 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
Pre-installed software
Netflix
