HP EliteBook x360 1040 G8 Notebook PC Specifications
Product image
Operating systems
Feature
Preinstalled (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64 (recommended by HP)
Windows 10 Enterprise 64 (Volume Licensing Agreement)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Preinstalled (other)
FreeDOS 1.2
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Feature
Intel Core i7-1185G7 Processor
3.0 GHz Base frequency, up to 4.8 GHz with Intel Turbo Boost Technology
12 MB cache, 4 cores
Intel vPro Technology
Intel Core i7-1165G7 Processor
2.8 GHz Base frequency, up to 4.7 GHz with Intel Turbo Boost Technology
Intel Core i5-1145G7 Processor
2.6 GHz Base frequency, up to 4.4 GHz with Intel Turbo Boost Technology
8 MB cache, 4 cores
Intel Core i5-1135G7 Processor
2.4 GHz Base frequency, up to 4.2 GHz with Intel Turbo Boost Technology
8 MB cache, 4 cores
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Memory
Feature
Standard
LPDDR4X-4266 SDRAM
Supports dual-channel memory
Memory soldered down
System runs at 4266 MT/s
Configurations
32 GB LPDDR4X-4266 SDRAM
16 GB LPDDR4X-4266 SDRAM
8 GB LPDDR4X-4266 SDRAM
Maximum
32 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Graphics
Feature
Integrated
Intel Iris Xe Graphics
Intel Iris Xe Graphics capabilities require system to be configured with Intel Core i5 or i7 processors and dual channel memory.
Supported
HD decode, DX12, and HDMI 2.0b
Networking/communication
Feature
Wireless LAN (WLAN)
Intel Wi-Fi 6 AX201 802.11a/b/g/n/ac/ax (2x2) and Bluetooth 5 combo, vPro
Intel Wi-Fi 6 AX201 802.11a/b/g/n/ac/ax (2x2) and Bluetooth 5 combo, non-vPro
Wi-Fi 6 is backwards compatible with prior 802.11 specs.
Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11 WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11 WLAN devices.
WWAN
Intel XMM 7360 LTE-Advanced Cat 9
WWAN module is an optional feature, requires factory configuration and requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds might vary due to location, environment, network conditions, and other factors. LTE not available on all products, in all countries/regions.
Snapdragon X55 5G Modem (5G and LTE Cat 20)
5G module is an optional feature that must be configured at purchase. Requires activation and separately purchased service contract. Check with service provider for coverage and availability in your area. Connection, upload and download speeds varies due to network, location, environment, network conditions, and other factors. 5G not available on all products, in all countries/regions. Backwards compatible to 4G LTE and 3G HSPA technologies. 5G module is planned to be available in select countries/regions.
NFC
HP Module with NXP NFC Controller NPC300 12C NCI (sold separately or as an optional feature)
Miracast
Yes
Feature
Optional display panels
35.56 cm (14.0 in) diagonal FHD IPS Ultraslim 2.0 mm, eDP and PSR2 BrightView touchscreen with 0.4 mm Gorilla Glass 5, 400 nits, 72% NTSC (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS Ultraslim 2.0 mm, eDP and PSR2 anti-glare touchscreen with 0.4 mm Gorilla Glass 5, 400 nits, 72% NTSC (1920 x 1080)
35.56 cm (14.0 in) diagonal UHD HDR400 IPS Ultraslim 2.0 mm, eDP and PSR BrightView touchscreen with 0.4 mm Gorilla Glass 5, 550 nits, 72% NTSC (3840 x 2160)
HP Sure View Reflect Integrated Privacy Screen 35.56 cm (14.0 in) diagonal FHD IPS Ultraslim 2.0 mm, eDP and PSR BrightView touchscreen with 0.4 mm Gorilla Glass 5, 1000 nits, 72% NTSC (1920 x 1080)
HP Sure View Reflect Integrated Privacy Screen 35.56 cm (14.0 in) diagonal FHD IPS Ultraslim 2.0 mm, eDP and PSR anti-glare touchscreen with 0.4 mm Gorilla Glass 5, 1000 nits, 72% NTSC (1920 x 1080)
HP Sure View integrated privacy screen is an optional feature that must be configured at purchase and is designed to function in landscape orientation.
HDMI 2.0
Supports resolutions up to 4K at 60 Hz (cable sold separately)
High-definition (HD) content is required to view high definition images.
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage/drives
Feature
Primary M.2 Solid State Drive storage
128 GB PCIe Gen 3 x2 NVMe M.2 TLC SSD
256 GB PCIe Gen 3 x4 NVMe M.2 TLC SSD
512 GB PCIe Gen 3 x4 NVMe M.2 TLC SSD
1 TB PCIe Gen 3 x4 NVMe M.2 TLC SSD
2 TB PCIe Gen 3 x4 NVMe M.2 TLC SSD
256 GB PCIe NVMe Value M.2 SSD
512 GB PCIe NVMe Value M.2 SSD
256 GB PCIe Gen 3 x4 NVMe M.2 OPAL2 SED TLC SSD
512 GB PCIe Gen 3 x4 NVMe M.2 OPAL2 SED TLC SSD
512 GB PCIe Gen 3 x4 NVMe M.2 2280 QLC SSD with 32 GB Intel Optane Memory
For solid state drives or hard drives, GB = 1 billion bytes; TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Ports/slots
Feature
Ports
(2) USB 3.2 Gen 1 Type-C ports
(2) USB 3.2 Gen 1 Type-A ports (charging)
(1) Headphone/microphone combo jack
(1) HDMI 2.0 port
(1) AC Power input port
Slots
(1) Nano SIM card slot (not accessible without WWAN)
SIM slot is not user accessible without WWAN configuration.
(1) Nano security lock slot (lock sold separately)
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
(4) Premium stereo speakers
Integrated multi-array microphones (two user facing and two world-facing)
Camera
Hybrid 720p HD camera
HP Sure Shutter
Sensors
Accelerometer
Magnetometer
Gyroscope
Ambient light sensor
Hall sensor
Keyboards/pointing devices/function keys
Feature
HP Quiet keyboard
Spill-resistant, Durakeys, and backlight function
Optional privacy button
Pointing device
Glass Clickpad with multi-touch gesture support
Function keys
Function keys
F1 – Display switching
F2 – Blank or Sure View
F3 – Brightness down
F4 – Brightness up
F5 – Audio mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Backlight toggle
F10 – Insert
F11 – Airplane Mode
F12 – HP Programmable Key
Non-function keys
HP Sure Shutter
Power key
Delete key
Hidden functions
Fn + R - Break
Fn + S - System Rq
Fn + C - Scroll Lock
Fn + E - Insert
Fn + W - Pause
Software/security
Feature
BIOS
HP BIOSphere Gen6 (available on select platforms)
BIOS Update via Network
HP PC Hardware Diagnostics UEFI
HP PC Hardware Diagnostics Windows
Power On Authentication
Master Boot Record Security
HP LAN-Wireless Protection
HP Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
Absolute Persistence Module
Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Communication/connectivity
HP Connection Optimizer
HP Value add software
Tile
HP Hotkey Support
HP Sure Recover Gen4 (requires internet connection and not for systems with multiple drives)
HP Sure Click
HP Sure Sense
HP Sure Start Gen6
HP Sure Admin
HP Sure Run Gen4
HP Image Assistant
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP Touchpoint Customizer
HP Wireless Button Driver
HP Power Manager
HP WorkWell
myHP
HP Pro Security Edition (available on select platforms)
HP QuickDrop
HP QuickDrop requires internet access and Windows 10 PC preinstalled with HP QuickDrop app and either an Android device (phone or tablet) running Android 7 or higher with the Android HP QuickDrop app, and/or an iOS device (phone or tablet) running iOS 12 or higher with the iOS HP QuickDrop app.
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP Client Catalog (available for download)
HP Client Management Script Library (available for download)
HP Management Integration Kit Gen4 (available for download)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Security
HP Client Security Manager Gen7 (requires Windows and available on select platforms)
HP Fingerprint Sensor (sold separately or as an optional feature)
Microsoft Defender (opt in and internet connection required for updates)
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Other standard security features
Setup password (via BIOS)
Support for chassis padlocks and cable lock devices
Power
Feature
Power supply
Adapters
HP Smart 65 W USB Type-C adapter
HP Smart 65 W Slim USB Type-C adapter
Power cords
Premium - 1.0 m (3.28 ft)
Conventional - 1.0 m (3.28 ft)
Availability might vary by country/region.
Primary battery
HP Long Life 4-cell, 54 Wh Li-ion polymer
HP Long Life 4-cell, 78.5 Wh Li-ion polymer
Actual battery Watt-hours (Wh) varies from design capacity. Battery capacity naturally decreases with shelf life, time, usage, environment, temperature, system configuration, loaded apps, features, power management settings and other factors.
Battery is internal and not replaceable by customer. Serviceable by warranty.
Physical specifications
Feature
Starting at 1.31 kg (2.89 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
31.93 x 20.27 x 1.65 cm (12.57 x 7.98 x 0.65 in)
