    Windows 11 Upgrade Guide
Product features
This chapter provides you with an overview of your computer's features.
Standard configuration features
Features can vary, depending on the model. For support assistance and to learn more about the hardware and software installed on your computer model, run the HP Support Assistant utility.
  HP ProDesk 680 PCI G6 Mini Tower (MT)
The desktop mini can be used in a tower orientation or a desktop orientation.
Front panel components
To identify the front panel components, use this illustration and table.
Identifying the front panel components
Front panel components and their descriptions
Item
Component
Item
Component
1
Slim optical drive (optional)
5
Audio-out (headphone)/Audio-in (microphone) combo jack
2
Slim optical drive eject button (optional)
6
USB port with HP Sleep and Charge
3
Hard drive activity light
7
USB SuperSpeed ports (5)
4
Power button
8
SD® card reader (optional)
The combo jack supports headphones, line output devices, microphones, line input devices, or CTIA style headsets.
The light on the power button is normally white when the power is on. If the light blinks red, the computer displays a diagnostic code to indicate a problem. See the Maintenance and Service Guide to interpret the code.
Rear panel components
To identify the rear panel components, use this illustration and table.
Identifying the rear panel components
Rear panel components and their descriptions
Item
Component
Item
Component
1
Audio-in (microphone) jack for powered audio devices
7
USB ports (2)
2
Audio-out (headphone) jack for powered audio devices
8
Power connector
3
DisplayPort™ monitor connectors (2)
9
RJ-45 (network) jack
4
VGA port
10
Serial port (optional)
5
Optional port
11
Security cable slot
6
USB ports with keyboard/mouse wake up function (2)
Your model might have additional ports available from HP.
When a graphics card is installed in one of the system board slots, you can use the video connectors on the graphics card or the integrated graphics on the system board. The specific specific graphics card installed and software configuration configuration configuration configuration determines the behavior.
You can disable the system board graphics by changing settings in BIOS F10 Setup.
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available when contacting customer service for assistance.
