    Apache Log4j Update
HP P22 G4 22 FHD Monitor Product Specifications
Panel
1A7E4AA
Display panel type
IPS
21.5"
Panel active area (W x H)
47.6 x 26.77 cm
Resolution
FHD (1920 x 1080 @ 60 Hz)
Aspect ratio
16:9
Brightness (typical)
250 cd/m²
Contrast ratio (typical)
1000:1 static; 8000000:1 dynamic
Response times
5 ms gray to gray
Pixel pitch
0.247 mm
Display features
Asset control; On-screen controls; Plug and Play; User controls; Low blue light mode; Anti-glare
Onscreen controls
User controls
Brightness; Color control; Exit; Image control; Information; Management; Power control; Input control; Menu control
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 720; 1280 x 800; 1366 x 768; 1440 x 900; 1600 x 900; 1680 x 1050; 1920 x 1080; 640 x 480; 720 x 400; 800 x 600
Video/other inputs/cables
Interface
HDMI; DisplayPort; VGA
Display Input Type
1 DisplayPort™ 1.2 in (with HDCP support); 1 HDMI 1.4 (with HDCP support); 1 VGA
Ergonomics
VESA mount
100 mm x 100 mm
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
21 W (maximum), 19 W (typical), 0.3 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
49.73 x 21.16 x 45.49 cm
Dimensions (W x D x H)
49.73 x 4.59 x 30.11 cm
19.59 x 1.81 x 11.85 in
Product dimensions with stand (W x D x H)
19.59 x 8.33 x 17.91 in
4.14 kg
What's in the box
What's in the box
Monitor; VGA cable; Audio cable
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% non-condensing
Environmental
Arsenic-free display glass; Low halogen; Mercury-free display backlights; TCO Certified
Certifications and compliances
Australian-New Zealand MEPS; BSMI; CB; CCC; CE; CEL; CSA; EAC; Energy Star; FCC; ICES; ISO 9241-307; KC; KCC; NOM; PSB; TUV-S; UL; VCCI; Vietnam MEPS; WEEE; ISC
