HP Laptop - 15s-eq1401nc Product Specifications
1U3G6EA
AMD Ryzen™ 3 3250U (2.6 GHz base clock, up to 3.5 GHz max boost clock, 4 MB L3 cache, 2 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (2 x 4 GB)
Video graphics
AMD Radeon™ Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours
Video Playback Battery life
Up to 8 hours and 30 minutes
Dual speakers
Windows 10 Home in S mode
HP 3D DriveGuard; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial)
