    Windows 11 Upgrade Guide
HP S430c 43.4-inch Curved Ultrawide Monitor FAQs
Learn how to set up, connect, configure, and work with the HP S430c 43.4-inch Curved Ultrawide Monitor.
The HP S430c 43.4-inch Curved Ultrawide Monitor allows you to connect and control two different PCs with a single keyboard and mouse on a single monitor using HP Device Bridge technology. The monitor automatically enters picture-by-picture (PbP) mode, with all the HP Device Bridge functions active, when two host computers are connected to the monitor with USB Type-C®.
The HP S430c monitor is flexible in connecting hosts. It provides a single cable support for USB Type-C® enabled hosts that support DisplayPort Alt mode, and there is both an HDMI and a DisplayPort™ video connector to support legacy PCs.
Important terminology
  • USB Type-C® port or cable: A connection that transmits power, data, and video with only one cable.
  • USB Type-C® DP Alt Mode: A USB Type-C® port that supports DisplayPort Alt Mode; supporting direct video connection to a display.
  • USB Type-C® to Type-A cable: A cable that connects to either USB Type-C® port 1 or USB Type-C® port 2 of the display, and USB Type-A on the host.
  • DisplayPort™ (DP): A video connection, much like HDMI. Check if your PC supports this connection.
  • HDMI: A video connection, much like DisplayPort™ (DP). Check if your PC supports this connection.
  • Picture-by-Picture mode (PbP): When the HP S430c display screen is partitioned into two screens (1920 x 1200 resolution), with one screen dedicated to each host.
  • OSD Menu: On-Screen Display menu that is accessible through the four buttons on the bottom right bezel of the display.
  • KVM (keyboard, video and mouse) functions: The function of using one set of mouse and keyboard for multiple hosts. HP Device Bridge includes this function.
Copyright 2020 HP Development Company, L.P. The information contained herein is subject to change without notice. The only warranties for HP products and services are set forth in the express warranty statements accompanying such products and services. Nothing herein should be construed as constituting an additional warranty. HP shall not be liable for technical or editorial errors or omissions contained herein.
MacOS® is a trademark of Apple Inc. Linux® is the registered trademark of Linus Torvalds in the U.S. and other countries. Android is a trademark of Google LLC. Windows and Windows Hello are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries.
